To Robert I owe appologies, you're right 30+ years ago triton had a plant locally, 7Kw and metal tank. Modern ones are plastic and 10Kw. Local chip shop, Bain marie, I happened to touch it and could feel a slight buzz, said to staff for a laugh I would check voltage on the casing of the unit, – 236V, SOMETHING IS WRONG ! Why has the trip not gone ? Nearly new, the unit was supplied with a continental 3 connection plug, plugged into a cheap adaptor to 13A, NO EARTH ! Called the owner, on liftting the pans out all was revealed ! The outer sheath of the heating element had burst leaving 10 or more turns in the water !!!!! By the grace of God nobody had touched the earthed range only 3 feet away and the plastic flooring had saved the staff. New element and a new plug !
Clive, as my ealier post states, Wilesco make/ sell the D32 which is a 220v electrically heated boiler and steam engine.
A phase shift dimmer and sub 1Kw heater would make a very controllable way to heat a boiler, but I would want a feed water pump as well. Noel.
Edited By noel shelley on 28/02/2023 11:19:53
