Electric motor test
Electric motor test
Home Forums Workshop Tools and Tooling Electric motor test
  • #601217
    Lee Rogers
      @leerogers95060
      I have a Bosch pro table saw that won't run. It has all the soft start and overload electronics and a no volt switch that one expects to find on a modern motor.
      The question is , if I bypass the switch and all the electronics and power it up directly should it run ? Will I damage it ?
      Lee Rogers
        @leerogers95060
        #601220
        Dave Halford
          @davehalford22513
          Better to put a light bulb across the motor feed and see if it lights up when you switch on or buy a cheap multimeter.
          Poke and hope with mains can be fun.
          #601223
          Mike Poole
            @mikepoole82104
            If it has a brushed motor as some do then check the brushes are not worn and are free in the holder and contact the commutator. Bypassing the soft start and control gear should not be a problem but if you are not confident with mains power then seek assistance. The fuse may fail with the inrush current but is likely to survive. The startup will be quite brutal compared to the soft start so be prepared.
            #601230
            Emgee
              @emgee
              Lee
              Check on the motor plate to confirm operating voltage and if AC or DC supply.
              Makers spec gives power output as 1.8kW so a direct connection will result in a fair current surge on start-up if connected direct.
              Emgee
              #601246
              Lee Rogers
                @leerogers95060
                Many thanks to all . Now to get the pixies flashing and smoking.
                #601252
                Jon Lawes
                  @jonlawes51698
                  Take the utmost care! We need all the members we can get!
                  #601254
                  noel shelley
                    @noelshelley55608
                    Very much depends on the type of motor, brush or induction and your knowledge. If it's induction then do not by pass the condensers, and fit some sort of switch. Good luck. Noel.
                    #601273
                    duncan webster 1
                      @duncanwebster1
                      I've never come across a soft start single phase squirrel cage motor. Connecting direct to the mains without a lot more information sounds risky to me
                      #601279
                        Is this the machine ?
                        https://www.bosch-professional.com/gb/en/products/gtm-12-jl-0601B15071920
                        Edit: __ If so, then it evidently has a brushed motor:
                        Edited By Michael Gilligan on 11/06/2022 05:59:33
                        Edited By Michael Gilligan on 11/06/2022 06:13:08
                        #601280
                          PostScript
                          I didn’t understand a word he was saying … but this might be of interest:
