Electric motor speed
Home Forums Workshop Tools and Tooling Electric motor speed
  • #561271
    KEITH BEAUMONT
      @keithbeaumont45476
      For many years I have had a Clarke "woodworker" circular saw. Recently,while cutting some MDF,the blade decided to free wheel. A strip down showed that the final drive gear key had sheared. Fortunatly I had a spare gear box taken from a previous motor that burnt out,some years ago.. What I have noticed is that the motor speed is reduced 2 to 1 by the gearing. The blade speed is 5000 RPM, so that means the motor is running at 10000 RPM. It looks like any normal brushed mains motor. No sign of any electronics to change frequency, so how is it done?
      Keith.
      KEITH BEAUMONT
        @keithbeaumont45476
        #561278
        Redsetter
          @redsetter
          Put simply, if it is an induction motor the speed depends on the mains frequency and the number of poles, but a brushed motor does not work that way.
          #561279
          Mikelkie
            @mikelkie
            Commonly called a universal motor, not to be run without load
            #561280
            Clive Foster
              @clivefoster55965
              Universal motors speed up until the load matches the drive power of the motor.
              If run without load they just go faster and faster until they either seize or grenade.
              Generally universal motors carry a cooling fan which presents enough load under overspeed conditions to prevent grenade. Usually.
              #561281
              KEITH BEAUMONT
                @keithbeaumont45476
                Redsetter,
                I did say it was a Brushed motor/
                Mikelkie,
                In what way does a Universal motor differ from a brushed mains type?
                Keith
                #561282
                KEITH BEAUMONT
                  @keithbeaumont45476
                  As there is nothing about not running it without a sawblade attached,,in the handbook, I assume the fan and gearbox provides sufficient load to avoid a runaway. When I reassembled the machine I did run it without a blade fitted, to check all was ok. I have a slow start unit fitted that takes 10 seconds to reach top speed and it did not continue to speed up after 10 seconds.
                  Thanks for the information.
                  Keith.
                  #561283
                  Redsetter
                    @redsetter
                    Posted by KEITH BEAUMONT on 04/09/2021 21:52:30:
                    Redsetter,
                    Mikelkie,
                    Keith
                    Yes I heard you the first time that is why I replied as I did! A universal motor is another name for a brushed mains motor. An induction motor is a totally different thing.
                    #561307
                    J Hancock
                      @jhancock95746
                      I think , ' universal' means it will also run on a dc supply , of the correct voltage.
                      #561316
                      Maurice Taylor
                        @mauricetaylor82093
                        Posted by Clive Foster on 04/09/2021 21:50:05:
                        Hi,Why doesn’t a mains electric drill with no load go faster and faster and seize ? These have brushes.
                        Maurice
                        #561319
                        roy entwistle
                          @royentwistle24699
                          Maurice A mains electric drill will have gears which will load it
                          #561321
                          Clive Foster
                            @clivefoster55965
                            Maurice
                            The common mains electric drill with brushed universal motor always has a cooling fan on the shaft which presents enough load to stop over speeding. Many have gearboxes too which also load things up.
                            For various reasons these motors have very little acceleration torque capability under overspeed condition.
                            If spinning up unloaded to grenade speed they will just keep accelerating but the actual acceleration curve has to fall into a fairly narrow band for it to keep going up. With no load the motor balances itself in the band and keeps going faster.
                            It is possible to make universal motors that are inherently incapable of overspeeding but, so far as I'm aware no one has bothered for many, many years. The price, performance, application ratios for such don't make sense. The whole point of modern universal motors is being cheap to make with lots of power in a compact, lightweight machine.
                            #561324
                            Maurice Taylor
                              @mauricetaylor82093
                              Hi,Clive. Thank you for your explanation .
                              Maurice
                              #561326
                              KEITH BEAUMONT
                                @keithbeaumont45476
                                Clive ,
                                Thanks from me.too
                                Question asked and anserwed !
                                Keith
                                #561335
                                Peter G. Shaw
                                  @peterg-shaw75338
                                  The blade speed will be a maximum for that blade, and must not be exceeded. Presumably because there is a danger of it breaking up. It is very unlikely that the motor will be running at 10,000rpm
                                  Peter G. Shaw
                                  #561341
                                  KEITH BEAUMONT
                                    @keithbeaumont45476
                                    Peter,
                                    I checked the RPM of the saw at full speed and got 4970 RPM. With a 2 to 1 reduction that means the motor is running at 10000. RPM, Hence my original question.
                                    Keith
                                    #561375
                                    Peter G. Shaw
                                      @peterg-shaw75338
                                      Fair enough Keith, you didn't say that and I assumed that your 5000 rpm was printed on the blade as a maximum speed.
                                      Just out of interest I've had a quick look at my mains powered hand held tools and found that the rpm as stated on the labels vary from 3000rpm (an aging B&D pistol drill) to 10,500 rpm (a 5" angle grinder bought from Aldi). Plus the max rpm for the 5" angle grinder disks is shown as 12,200 rpm. So maybe your 10,000 rpm is indeed possible.
                                      Peter.
                                      #561381
                                      Mike Poole
                                        @mikepoole82104
                                        A brushed motor can be series or shunt wound also compound wound, the series motor is the one to be careful about running without a load as it is possible to reach speeds that destroy the motor armature or bearings. The series motor will also run on an AC orDC supply hence the universal name.
                                        #561383
                                        old mart
                                          @oldmart
                                          It would be common for the brushed motor of a router to run at 25000 rpm.
                                          #561385
                                          not done it yet
                                            @notdoneityet
                                            Posted by old mart on 05/09/2021 15:23:58:
                                            Think routers here? Even Dremels.
                                            #561419
                                            Robert Atkinson 2
                                              @robertatkinson2
                                              The speed of DC or universal motor does not increase to infinity without load even without friction and windage. It increases unti the armature back EMF, which is proportional to the speed, equals the applied voltage. For some series motors this speed exceeds the mechnical rating of the parts unless a load is applied.
                                              In theory both shunt and series wound brushed DC motor will run on AC or DC. However the inductance of the field winding on a practical shunt motor is too high to allow enough current to flow even at 50Hz.
                                              Robert G8RPI.
                                              #561437
                                              Bazyle
                                                @bazyle
                                                I have a brushed mains motor from a Hotpoint washing machine labelled at 15000rpm. The small pulley on the motor and huge one on the drum is needed to tumble that overload of wet socks yet once going it needs to go like a bat out of hell to do the spin. The motor actually turns itself over on 12v and is quite useful on 70vDC. About 20 years ago at a model show there was a submarine some 15ft long using two of them.
