Hi everyone,
Thanks again for all the suggestions. Apologies for the delay.
To give a little more detail about my project, I am trying to create a water bath that is at a constant -10 degrees Celsius. To do this, what I panned to do is pump water to and from this water bath via a peltier system. The main tubing will most likely be plastic tubing (about 2 mm ID, and 5 mm OD, and is also insulated) but will then feed into copper tubing (4mm OD) to pass over the peltier device. I am using two peltier devices staked on top of one another and with this I can get a stable -15 degrees on top of the cold side of the peltier. I have not measured the heat on the hot side of the peltier but I am using a system of heat sinks and fans to dissipate the heat.
Also, just another point, I add about 2 molar salt to the water to hopefully stop it freezing when being pumped around the solution. If this does not work, I will look into using some other form of coolant (not looked into this at all yet).
I initially planned to use a water cooling block on top of the peltier to cool the solution, but, I want the solution to be on top of the peltier for as long as possible (to transfer as much coolness as possible) and the water cooling blocks I have seen only have about 3-4 turns, therefore likely to pump the solution across the peltier for only a very short time (the pump rate will be about 25 ml/min). This is why I thought it better to use small copper tube that makes as many passes as possible across the top of the peltier. Also, all the water cooling blocks I found had large diameter openings (at least 8 mm) – I was not sure if this would work with my plastic tubing with an ID of 2-3 mm.
Once the copper spiral had been made, I was planning to weigh it down on top on the peltier. I would put insulation in between the weight and the copper tubing to stop the cold temperature being transferred to the weight.
Further details: heat-transfer paste will be used between the copper tubing and peltier. The pump rate will be about 25 ml/min. The copper tube system will be covered in insulating material as much as possible. If possible, I may even use copper tube with a smaller diameter (to increase the number of turns on the peltier)
Hope this makes the project more clear. Thanks a lot once again for the suggestions.
Tim
