I went through this process on my little CNC mill, mounting a CCD microscope on the side of the column and using the CentreCam software. Obviously the 'scope centreline is offset from the spindle axis when you do this. In order to evaluate the offsets I used the following process.
- Used a spotting / centre drill to make a very small dimple on the surface of a bit of stock
- Zeroed the axes
- Moved the table until I got the surface of the stock in focus and the centre of the dimple on the cross hairs.
- The values of the axes, with reversed sign, give you the offsets of the spindle from the microscope.
However I have never found the method very useful because it's a faff and manual, much better to have a probe linked to the controller and find the edge or centre automatically.
You can see some pics in my "Microscope" album.
Edited By John Haine on 21/11/2020 10:02:39
