Hi Dick
y,
These are metric dimensions. The fits on the crankshaft are less than those for the case.
You should just be able to push the front bearing on the shaft by hand, the rear bearing just a little tighter.
The bearings need to be tighter in the case than on the shaft and will fit easily with the tolerances shown if you heat the case with a hot air gun or in the oven. Drop the front bearing in the case then with the rear bearing already on the shaft this should just slide in the case if it hasn’t cooled too quickly. I have used this method on many occasions and it works just fine
These fits are not taken from from the usual laid down sources but are what the originals were made to which I find is more than sufficient for the task in hand – these engines, ie the 5cc version, when designed were not intended to be used in a high speed operational environment. The shaft tolerances are easily achieved by careful use of wet and dry paper – about 600 grit – especially if stuck with double sided sticky tape to something really flat – eg a parallel . Plenty of paraffin and oil (90 -10) mix and constant measuring is the key
I don’t think the misnomer – “A 5cc
racing engine” is of my doing
I hope your engine is going well
Regards Ramon
