Eclipse Magnetic Chucks
Home Forums Workshop Tools and Tooling Eclipse Magnetic Chucks
  • #42398
    Robbo
      @robbo
      Can anyone suggest the name of a suitable oil to fill an Eclpse Magnetic chuck?
      The Eclipse handbook merely specifies SAE 140 gear oil.
      I obtained a 5″x10″ chuck, and found it to contain no oil at all, no wonder it was stiff!
      Robbo
        @robbo
        #42402
        LADmachining
          @ladmachining
          Google is your friend!
          First search result:
          I am sure there are loads of other retailers selling the stuff.
          Anthony
          Edited By David Clark 1 on 18/07/2009 10:54:57
          #42416
          Robbo
            @robbo
            Thanks for that, at least I know that I am not looking for some out of date product, and it should be readily available.   All I have found locally so far is 80-90 SAE, and that was EP, which additives don’t behave well with Phosphor bronze and brass, and I am sure there’s some of that in the chuck, if only in the operating lever bush, and that already oozes a bit.
            Phil
            #43017
            Robbo
              @robbo
              Following the advice, I have got some Morris Lubricants AG140, and good it looks.   The only problem is I had to get it by mail and had to get a big can, so if anyone else needs a small quantity, as I did, then get in touch.
