Eclipse 39 assistance please
Home Forums Beginners questions Eclipse 39 assistance please
  • #475927
    Paul Barter
      @paulbarter66156
      Hello all, I have used the Picador drill sharpening jig, but it is a time consuming activity. I thought that the Eclipse 39 jig would be a better bet for a minor restoration of a failing edge. My problem is that the one I bought did not come with instructions and it is not clear to me how to set drills for correct angles, can anyone give me some idea as to how correctly install drills for sharpening,or tell me where I may obtain a user guide? Google has failed me so far.
      Thanks for any information Paul Barter
      Paul Barter
        @paulbarter66156
        #475934
        Martin Connelly
          @martinconnelly55370
          This came up 13 months ago. Don't think you should hold your breath.
          Drill sharpener thread
          Martin C
          #475936
          Paul Barter
            @paulbarter66156
            Thanks for the link Martin, not encouraging reading! I need to practice freehand sharpening,for tool bits as well!
            regards Paul
            #475950
            Andy Stopford
              @andystopford50521
              Copied from this ad https://www.adverts.ie/machinery-tools/eclipse-no-39-drill-bit-sharpening-jig/2667142
              Manual for Eclipse no 39 drill bit sharpening jig
              For sharpening twist drills in a range of sizes from 3mm (1/8 inch) to
              13 m (1/2 inch)
              Assembly
              Remove small chrome plated screw from strut. Assemble struct
              into body. Fit screw and tighten up.
              Instruction for use
              1 Hold strut with V channel uppermost.
              2 Release back stop and slide to end of strut
              3 Loosen drill clamping screw
              4 Insert dril into V strut with point away from back stop. Hold drill
              in V with thumb. Upturn sharpener to bring drill point into view, align
              one cutting edge parallel to and flush with front gauge, which is
              adjustable for different drill size.
              5 Lightly tighten drill clamping screw
              6 Swing aside back stop shim and slide back stop into contact with
              the drill shank and tighten
              7 Swing shim back into V. This will advance drill the required amount
              for sharpening.
              8 Check that the drill is still correctly aligned with front gauge and
              fully tighten drill clamping screw
              9 With one hand hold sharpener between thunmb and finger in side
              recesses and with the other hand hold abrasive paper on a smooth flat
              surface
              10 Roll sharpener up and down the full lenght of the abrasive paper
              until cutting ceases
              11 Fully release drill clamping screw rotate drill 180 and align second
              cutting edge with front gauge
              12 Ensure drill shank is in contact with back stop shim and tighen
              drill clamp screw.
              13 Repeat sharpening action
              14 If drill is not completely sharpened, repeat from 6
              Note
              (a) use whole surface of abrasive paper
              (b) do no allow wheels to slide
              #475956
              Paul Barter
                @paulbarter66156
                Hi Andy, Thank you for your post, just what I need, so no burnt fingers just yet
                regards Paul
