Tony, the eccentric sheave is in whole oversized cast iron in the cast iron set of triple steam engine. Is it not better to drill/tapping the hole for the 7 BA screws first then splitting the eccenter sheave to make exact location when the splitted sheave is screwed togheter?
I has not problem to make the double eccenter, i used the jig with degree disc for lathe when i maked the double eccenter for Stuart D10 who has reversible gear.
Edited By Jens Eirik Skogstad on 11/09/2013 22:09:13
Edited By Jens Eirik Skogstad on 11/09/2013 22:09:51
