Thanks for your help – I discovered that when I shortened the grub screws I hadn't put back the point! _ so that certainly didn't help the situation.
Stew, yes the sheaves are tight when it's all bolted together – I'm not sure how to resolve the situation however, I do not want to remove the eccentrics so pehaps I need to skim the inside of the sheaves – so much for trying to make things a good fit – perhaps I should have gone sloppy fit.
Richard, it's a Stirling Single in 5"
Consensus of opinion seems to be just edging towards grub screws – possibly with a drill tip hole in the shaft when all is set.
Edited By Quentin Reidford on 29/09/2013 18:45:56
