Easy power tailstock feed for your lathe
Home Forums Workshop Techniques Easy power tailstock feed for your lathe
  • #597507
    Bill Kunz
      @billkunz39862
      Many years ago I came up with a simple power feed arrangement for the tailstock on my 9" South Bend lathe when drilling, reaming, tapping, etc.
      I got a two piece clamping shaft collar with an ID the same size as my tailstock spindle. Then I made a forked bracket that engaged the shaft collar as shown in the photo. Bingo, I had a power tailstock feed. Just slightly loosen the tailstock clamp and let the carriage pull it along at the desired feed rate.
      Power tailstock feed 3
      Power tailstock feed 1
      Edited By Bill Kunz on 09/05/2022 02:15:18
      Bill Kunz
        @billkunz39862
        #597514
        Nicholas Farr
          @nicholasfarr14254
          Hi Bill, that's a novel idea.
          Regards Nick.
          #597516
          Thor 🇳🇴
            @thor
            Thst is a neat way to get powered tailstock feed, I saw it here some time ago, but haven't had time to make one yet.
            Thor
            #597529
            Clive Brown 1
              @clivebrown1
              Posted by Bill Kunz on 09/05/2022 02:14:27:
              Many years ago I came up with a simple power feed arrangement for the tailstock on my 9" South Bend lathe when drilling, reaming, tapping, etc..
              I'd question the desirability of a powered feed for tapping, especially in a fairly small lathe.
              #597532
              Hopper
                @hopper
                I think I'd be using spiral flute taps if driving them in under power. But could be handy for drilling, as long as drill bits are well sharpened and don't clog the flutes. I have used power feed drill presses plenty of times and they work well.
                I suppose you could do the same thing by putting a bit of square bar in the toolpost and putting it up behind the chuck body itself. The taper should be enough to pull the unloaded tailstock along with it. Might have to try that sometime. Specially with the lever tailstock in place, the quill would just follow the chuck along without strain. I might even have a go at making a Y shaped attachment that goes straight in the toolpost and engages with the back of the chuck, so quick and easy installation and removal and no collar on the quill taking up valuable travel.
                I wonder what sort of feed rate one uses for power drilling compared with turning? Setting up the change gears for other than standard fine feed of about 2 thou per rev would be not worth the faff on my Myfrod.
                I like the concept though.
                Edited By Hopper on 09/05/2022 09:30:15
                #597536
                Nigel Graham 2
                  @nigelgraham2
                  Neat idea!
                  I think I'd rather use a tapping-head for that, though – there is incidentally an old way to use a tap of appropriate pitch, in a suitable tool-post holder, as an internal chaser for much larger diameters than the tap itself.
                  Using a large drill, it may better if the driving bar is one that extends back and pulls the tailstock body as a whole, rather than risking unloading the taper as could happen if the drill snatches. That may be a greater risk on screw-fed tailstocks, than with a lever feed.
                  #597537
                  John Hinkley
                    @johnhinkley26699
                    You could prevent any potential wobble from an over-loose tailstock by mounting a chuck on a sliding shaft held in the tailstock taper, much like a tailsock-mounted die holder. Or, less easily, Do it like Stefan.
                    Tim Stevens
                      @timstevens64731
                      Also useful for boring, using a boring head held in the tailstock.
                      Cheers, Tim
                      #597548
                      ega
                        @ega
                        Nice to see vintage (black and white) photos of a vintage lathe!
                        #597574
                        Bill Kunz
                          @billkunz39862
                          Posted by ega on 09/05/2022 10:47:43:
                          Here's another:
                          South Bend Model 9A
                          #597613
                          bernard towers
                            @bernardtowers37738
                            There has been one in the past fitted to a Myford with a bracket fitted to the lower front portion of the tailstock and a connecting piece fitted to a t slot on the crosslide, was always going to make one but its still on the list!
                            #597634
                            Mike Poole
                              @mikepoole82104
                              I watched this video a couple of days ago by Stefan Gotteswinter describing his use of a toolpost mounted drill chuck and how it is very practical for speed of working.Toolpost Drilling
                              #597650
                              Peter Spink
                                @peterspink21088
                                Posted by Nigel Graham 2 on 09/05/2022 09:31:15:
                                Neat idea!
                                Assuming a lever feed, is it possible to use a tapping head in the tailstock?
                                #597669
                                David-Clark 1
                                  @david-clark1
                                  Watching
                                  #597723
                                  old mart
                                    @oldmart
                                    When we were working on the museum's Smart & Brown model A apron there was no way to use the lathe to produce the bushes and spindles needed. I did the exact opposite, using the tailstock to push the saddle using an extra piece of metal bar in the four way toolpost. I backed off the tool and manually returned the saddle to the start position after each cut.
                                    #601936
                                    Nigel Graham 2
                                      @nigelgraham2
                                      Have just watched Stefan Gotteswinter's video – thank you for the link, Mike.
                                      Very interesting ideas, not just in the drilling, either.
                                      I had pondered the feasibility of a chuck-holder held and driven by the saddle but located directly by the bed, obviating having to align it every time. Using the saddle to pull the tailstock along sort of does that, but you've still the problem of a long overhang, especially with short drills, for the drill even to reach the work.
                                      I must admit a 6-jaw chuck is new to me. I might vaguely have heard of them but never seen one in the metal, so to speak.
                                      He says a centre-drill is wrong for spotting. Well, I won't argue with that, as it's often said by model-engineers rather nearer the Gold Medal than I'll ever be; but this does seem a recent development, and I don't recall seeing an explanation why they are fine for their named use but not for starting a drill.
                                      Regarding his counter-sinking the hole before tapping, assuming sensible metal depth I usually counter-drill to nominal full diameter to just below the surface, one to two thread turns worth. I still lightly chamfer the edge.
                                      0.2mm drills….. I worry about whopping great 2 whole-millimetres…. (Like last night, in the bench-drill, making split-pin holes across 1/4" dia steel.)
                                      #601938
                                      Hopper
                                        @hopper
                                        Posted by Nigel Graham 2 on 16/06/2022 00:50:08:
                                        It seems to be a recent thing developed with CNC to eliminate the breaking off of the tip of centre drills when quickly starting a drilled hole. Traditionally we were always taught to start a drilled hole in the lathe with a centre drill. Probably because that is what we had in those days, and we were (supposedly) skilled enough to avoid breaking the delicate tip off a centre drill.
                                        So you can start a drilled hole with a centre drill if you want but with short spotting drills readily available today it is quicker, easier and safer to use a spotting drill and save the careful centre drilling for those occasions when you want to use a tailstock centre in the hole afterwards. It saves wear on your centre drills too.
                                        At home, I sort of have five bob each way and use a centre drill with about a 7/16" shank and 3/16" tip and just use the very end of the tip to put a small divot in the job to start the next drill, in effect using the large centre drill as a spotting drill. Again, because that is what I have. I bought some cheap spotting drills but they have one full turn of flute on them and seem to flex too much and run off centre. Must get some of the proper ones with about a quarter of a turn of flute and much more rigid.
