Easy method of 4 jaw centering
Home Forums Beginners questions Easy method of 4 jaw centering
Viewing 25 posts - 1 through 25 (of 29 total)
  • #493674
    jon hill 3
      @jonhill3
      I am having great difficulty centering an independent 4 jaw chuck does anyone have any quick or fool proof methods?
      jon hill 3
        @jonhill3
        #493677
        Ady1
          @ady1
          I use the toolpost / side of the tool and finish with DTI
          You can do the job 98% by eye
          It's like sex
          The more you do it the easier it gets
          #493678
          roy entwistle
            @royentwistle24699
            Use two chuck keys on opposite jaws
            #493679
            IanT
              @iant
              Depends on what kit you have to hand. I generally use two centres and a DTI
              IanT
              #493681
              Former Member
                @formermember12892
                #493683
                jon hill 3
                  @jonhill3
                  Thanks guys all useful tips, currently I just use a dti on say round bar.
                  I think I will make a new 2nd key as my next mini project.
                  #493684
                  Mick B1
                    @mickb1
                    If you can grip the piece in the drill chuck, offer it up from the tailstock end and carefully close the chuck jaws onto it. You should be within a few thou and well inside clock gauge territory by then.
                    #493686
                      Posted by roy entwistle on 01/09/2020 11:16:53:
                      +1
                      And practice!
                      I position the job roughly by eye, sometimes using a centre in the tailstock as a reference, sometimes with the lines on the chuck, at this stage not tightening the jaws.
                      Easiest and most accurate to measure offset with a DTI, but it can be done by eyeballing the gap between a cutter and job.
                      With two jaws horizontal, set the DTI. Then rotate through 180 degrees to measure the difference. Turn the keys in opposite directions to halve the difference, tighten one while slackening the other. Rotate back through 180 degrees, measure the new difference and halve again. Then set the other two jaws horizontal and centre them with the same process.
                      At this point, the job should be more-or-less accurately centred. Spin through a full turn to see how good or bad it is, and repeat the 'halve the DTI difference' with two chuck keys as necessary.
                      Tricky bits;
                      • During adjustment making the jaws tight enough to hold the job without being so tight as to make halving difficult.
                      • Learning to turn two chuck keys together and in the right direction! (I still get this wrong occasionally)
                      • Tightening up at the end without disturbing the centre setting.
                      I cracked it by spending a few hours doing nothing but centring various objects in my 4-jaw. Initially I had to think every move out, now it comes naturally.
                      Edited By SillyOldDuffer on 01/09/2020 11:44:34
                      #493688
                      Hopper
                        @hopper
                        Two chuck keys are good. Getting it roughly right by eye against the tool bit is good.
                        Then the easy way to finish off is this:
                        • Put dial indicator on the round bar and rotate the chuck once.
                        • Note the highest and lowest dial gauge readings.
                        • Set the 0 mark to exactly halfway between the two readings. (Rotate the job one more time to check you are now getting identical plus and minus runout readings.)
                        • Go around each jaw and set it so the dial gauge is reading 0 as each jaw is next to the dial gauge.
                        • When the reading next to all four jaws is 0, the job is trued.
                        I did it the old, hard, trial-and-error dial indicator way for 40 years before discovering this so-simple no-brainer quick method. Hope you are smarter than I was. The simplicity and effectiveness of this method still leaves me gobsmacked.
                        Edited By Hopper on 01/09/2020 11:51:05
                        Edited By Hopper on 01/09/2020 12:04:08
                        #493692
                        Alan Johnson 7
                          @alanjohnson7
                          By eye – use the tool or tool holder to give you an indication. Then, digital DTI. It is easy (if you have one). Set to zero at jaw 1, rotate to jaw 3. DTI will give you a + or – error. Halve it, and adjust jaws to correct. Likewise jaw 2 and 4.
                          Practice on a bit of round bar first. As others have said "prctice makes perfect."
                          #493697
                          Gary Wooding
                            @garywooding25363
                            I use a method which is very quick and accurate, but not, it would seem, very well known.
                            ***THIS*** PDF explains the method.
                            Although not absolutely necessary, the use of two chuck keys makes life much easier.
                            #493702
                            Tony Pratt 1
                              @tonypratt1
                              Never felt the need for 2 chuck keys & lots of practice works wonders.
                              Tony
                              #493709
                              not done it yet
                                @notdoneityet
                                If it is smallish round bar, you need to get it fairly close before tightening anything. Otherwise, if two jaws are OK and you are trying to adjust the other pair, the tight jaws may prevent the bar from moving as you might expect it to – due to trying to force a larger diameter through the already tight pair of jaws.
                                Quite often, I don’t bother to change from a 4 jaw independent chuck to a self-centring one unless for a better reason than centring the odd new workpiece (I might if I was using smaller chucks than 160mm🙂 ).
                                #493713
                                duncan webster 1
                                  @duncanwebster1
                                  Posted by IanT on 01/09/2020 11:17:24:
                                  IanT
                                  Instead of 2 centres I have a bit of 3/16" rod about 12" long with a point on one end. Grip the non pointy end in the drill chuck in the tailstock and apply DTI towards the pointy end. Saves swapping from chuck to centre. One of these days I'll get round to loctiting a bit of bigger stuff to the non pointy end so that the DTI can be applied when the eccentricity is higher. I'll put a flat on it so it doesn't roll off the shelf, but not run the DTI on the flat.
                                  When applying it to the centre pop, I wind the tailstock out until the handle is at the back before locking the tailstock, The weight of the handle then keeps the point in the mark
                                  #493715
                                  Howard Lewis
                                    @howardlewis46836
                                    Like IanT I use two centres, and a finger clock as the job comes nearer to being centred.
                                    This is extremely helpful where the job is either deliberately eccentric, or irregular in shape.
                                    I made a second key for the "baxk" jaw, but very rarely use it.
                                    Practice makes perfect. the more that you do it, the easier and quicker it becomes to centre work.
                                    #493729
                                      Posted by Hopper on 01/09/2020 11:47:04:
                                      … the easy way to finish off is this:
                                      Just tried Hopper's method only to find it took longer. Despite understanding the logic I slowed down just because the method is slightly different from what I'm used to. Hard to break old habits I guess. I shall persist : Hopper's way must be easier!
                                      Gary Wooding
                                        @garywooding25363
                                        Posted by SillyOldDuffer on 01/09/2020 15:29:57:
                                        It is – it's the same way as described in my link.
                                        #493740
                                        mechman48
                                          @mechman48
                                          IanT
                                          This is also my preferred method, have also used the two chuck keys method.I find this one the easiest.
                                          George.
                                          #493792
                                          Hopper
                                            @hopper
                                            Posted by Gary Wooding on 01/09/2020 16:21:30:
                                            It's not my way. I saw it published in MEW about 2 or 3 years ago. Can't remember the author's name. A Scandinavian chap maybe. He described it more clearly with illustrations.
                                            #493799
                                            peak4
                                              @peak4
                                              Here we have quite neat way of centring square bar in a 4 jaw.
                                              Bill
                                              #493812
                                              Paul M
                                                @paulm98238
                                                I have used the same method as Hopper's for years now. I can centre work quickly and have yet to find an easier method for entering round stock.
                                                Find low and high points
                                                Move work to halve the difference and set dti to zero
                                                Go round jaws and set to zero
                                                I don't bother with using two chuck keys in apposing jaws.
                                                Spend an afternoon just centering work.
                                                Students I taught always found this method easiest to learn.
                                                #493818
                                                Clive Foster
                                                  @clivefoster55965
                                                  A quick way to get very close without needing a DTI uses the cross slide dial to measure the error and a support block between the bed and chuck jaw to hold the jaw exactly horizontal.
                                                  Start by putting the job in the chuck at your best guess to central. Choose a jaw to start with and set it horizontal using the block. Arrange some sort of rigid probe on the tool post with a vertical face to contact the work. For example a hefty rectangular tool set backwards in the tool post with its end dead vertical works fine. If you have a QC post the vertical face of an empty holder may well work. The driil carriers from Dickson systems work fine for this. Nice to find a use for it!
                                                  Run the cross slide forwards until the probe lightly touches the job. If you don't trust your feel or if doing a small job in a bigger, less sensitive machine, trap a piece of cigarette paper or 1 thou feeler gauge just enough to be stiff to pullout. Note the cross slide reading.
                                                  Pull back, rotate the chuck by 180° and repeat. Set the cross slide to halve the difference and adjust the chuck jaws so the work just touches the probe.
                                                  Rotate 180° and verify that the cross slide readings are very close. Adjust again if more than 10 thou out.
                                                  Repeat process with the other pair of jaws.
                                                  Given a modest level of care its easy to centre the job to better than 10 thou TIR first time round. With practice right first time may become normal for anything other than the most exacting jobs.
                                                  Go round again for the final adjustment if needed. When finishing off you may prefer to leave the probe sitting very close to the work and make the final tweak using feeler gauges instead of the dial. Expect something under half a thou TIR to be easily achievable.
                                                  I imagine the process works well with a DRO.
                                                  This was the method I was shown for square stock. Took 30 odd years to twig that it would work well for round work too. By which time I had a nice stock of dial indicators.
                                                  #493819
                                                  Martin Kyte
                                                    @martinkyte99762
                                                    For the items with a centre pop wind the jaws clear of the item and hold against the back of the chuck with the tailstock centre. Adjust the jaws until gently touching and then proceed with the spring centre and dial guage or spare centre and dial guage as describe in this thread.
                                                    regards Martin
                                                    #493831
                                                    Gary Wooding
                                                      @garywooding25363
                                                      Posted by Hopper on 01/09/2020 22:55:40:
                                                      In that case it's not surprising 'cos I wrote the MEW article you saw. My link was the actual article.
