On another general thread a DRO issue was traced to a faulty safety earth on a new machine (not the DRO). The earth connectin was a ring tag onto a painted panel resulting in no earth. The machine came from a known UK supplier.
It is clear that in this case there was a design and or manufacturing issue as well as lack of testing.
This type of issue is hidden until another fault occours. then it could cause electrocution, fire or injury caused by pulling a hand away due to a mild shock and contacting a rotating part or sharp cutter.
While the other case was a particular make model, this could apply to any machine tool new or used.
Even if a check carried out with a multimeter shows low resistance to earth, this does not assure adequate earthing in the event of a fault. Ad a proper earth path has not been designed in, a stray connection through a burr of single wire strand will show low resistance but could fuse in the event of an insulation failure leaving the machine live, The only adequate test is a high current bonding test. This measures the resistance with a high current, typically 20A for equipment with a 13A plug, appled for at least a second.
A check with multimeter will pick up gross errors and I strongly recommend that owners of small machines carr out at least this basic check before first use, if they have been moved or modified and ideally every couple of years.
BASIC EARTH CHECK.
1/ Unplug machine, including any accessories like lights, DRO's etc.
2/ Using a multimeter select the lowest Ohms range (or auto)
3/ connect the test probe tips / clips together and note the reading. It should be less than 1 Ohm. For a analog meter zero the meter.
4/ Connect one meter lead to the earth pin of the mains plug.
5/ For each main exposed metal part of the machine connect the ther meter probe to it and check the meter reading. If an auto-ranging meter make sure it is still reading Ohms and not kiloohms or Megohms
6/ subtract the reading noted in 3/
7/ If the result is more than 0.5 Ohms the machine may be faulty and should not be used until properly inspected and tested by a competent person.
The main parts to check are the control box, Bed or main casting, Motor casing if exposed and spindle. Items like control handles should be checked but only ones that might become live are critical. For rsample a mill Quill feed wher the drive goes into a housing that has wiring in it must be grounded, but a cross-slide handle is not critical because athe bed and slide, or chuck, would have to be live first. If getting someone else to check, make sure they are competent, in my experience most individuals offering "PAT" testing services are not competent to check a machine tool .
Robert G8RPI.
