EAGLE users?
EAGLE users?
Home Forums Electronics in the Workshop EAGLE users?
  • #222060
    John Rudd
      @johnrudd16576
      I've been using the latest version…..7.5
      Creating a schematic, not a problem but when I added a 4069 hex inverter, there are no power connections to it…..I selected the 14 pin dil version from the menu…..
      John Rudd
        @johnrudd16576
        no power pins to ic
        #222062
          Eagle is 'orrible isn't it. Nothing works like a standard windows program. I'm changing to Design Spark when I can figure out how to import my eagle projects and libraries – get rid of that 100mm square limit!.
          As for your problem, the answer is totally anti-intuitive!
          Place your gates, and then right click one of them and choose 'invoke', now select PWRN and it will let you place power connections.
          Don't ask me how I remembered how to do that, I suspect its because it took me four days to figure out how to do it…
          Yep, Eagle is the most user-unfriendly Windows program EVER!
          John Rudd
            @johnrudd16576
            Thanks Neil,
            Hopefully you are over the pain it caused you..😀
