I have an Eagle surface grinder (not sure of the exact model – the bed measures 21 x 8" and the serial number may indicate this is model "4" ) that is currently fitted with a 1.25HP 380/440V 3-phase motor. This is a 2-pole 2850 RPM motor.
My intention is to remove the motor and see if I can dig out the star point and rewire as delta. Alternatively, I have numerous other 3-phase motors to hand which have a nice compact form-factor and will fit the existing space. Newer motors (e.g. 80 frame) will likely foul the lead screw.
Off the top of my head, I have a choice of 0.75 HP, 1 HP and 1.5 HP all of which are 4-pole motors therefore running at 1425 RPM @50 Hz. To maintain the grinding wheel speed I would need to increase the motor pulley size. Under no-load conditions this would obviously work fine but would it perform poorly when grinding? I suspect the higher speed motor would be the better option but as I have some "free" motors the only cost will be my time boring / bushing a pulley from my junk box and trying this out.
Your comments, please.
Edited By AJAX on 16/04/2022 08:00:50
