Eagle Surface Grinder
Home Forums Beginners questions Eagle Surface Grinder
  • #56619
    Gray62
      @gray62
         I have a Mk2/3 eagle surface grinder which whilst adequate for most purposes could be improved with wet grinding facilities. I am aware that these machines were supplied with a wet grinding facility and would appreciate any information, pictures etc of such a machine. I don’t think the conversion would be a difficult one but any information on how this was implemented by the manufacturer will be4 very much appreciated.
      Gray62
        @gray62
        Wet Grinding
        #56628
        Bogstandard
          @bogstandard
          Have you considered a spraymist system?
          I have made one for my lathe, and am just about to do them for my mill and Herbert surface grinder. A lot less mess than flood coolant. The only drawback is you have to have piped air.
          Bogs
          #56637
          David Colwill
            @davidcolwill19261
            I made a spraymist for my triac CNC mill and had to stop using it because I hadn’t set up proper extraction for the resultant vapour. I ended up with a workshop full of choking ‘fumes’ which were painful to breathe and made me feel quite ill. The actual unit though was very effective. I would advise that anyone planning on using this system checks out the relevant health and safety issues for these things. Used correctly I’m sure they are fantastic And I do hope to resurrect mine when I can put a suitable enclosure around the machine.
            Dave.
            #56644
            Pete Jones
              @petejones68962
              There’s a small photo of an Eagle 5W (the wet version) on the inside back cover of ME 4360 (11th Sept 2009) in the Home and Workshop Machinery ad. Although small it does seem to show the main differences. I would have thought the biggest issue would be coolant filtration prior to recirculation.
              Pete.
              #56646
              Bogstandard
                @bogstandard
                Dave,
                That is all to do with badly adjusted nozzles, not the requirement of an extraction unit.
                I get no fogging at all from mine, and it uses very little air or cutting fluid. In fact, I use it as a total loss system, just a quick wipe away when I have finished.
                I can part off a 3″ lump, and the bit that falls off is cool to the touch, not smoking as normally happens.
                It is the air that does the cooling and swarf blow away, and you only require tiny amounts of cutting fluid.
                Bogs
                #56670
                Gray62
                  @gray62
                  Hi Bogs,
                  I’ve read that post a few times recently, I’ve been thinking about something along those lines, do you have any dimensioned drawings
                  Your posts are very informative, I’ve just finished making the tramming tool you documented in another post,
                  many thanks
                  CB
                  #56676
                  Bogstandard
                    @bogstandard
                    CB,
                    Sorry, that project got held up when my body decided to rebel against me, so I only ever got to make the first one, which was a prototype anyway. So no drawings were done, as it was made on the fly.
                    But it proved the system, and once I get back into the swing of things again, I will make a simpler version, by using the figures I obtained from this one. It doesn’t need to be anywhere near as complicated as the one I made.
                    Bogs
                    #56706
                    Hugh Gilhespie
                      @hughgilhespie56163
                      Bogs
                      I would also be very interested in the updated spraymister whenever you get a round tuit. No rush, I have yet to sort out the air system in my workshop, but I am planning on having air outlets at the lathe, mill and shaper specifically for spray mist cooling. I like having coolant and think it does make a difference, even with carbide tooling.
                      PS – I also made your tramming tool – it’s so good that now I even look forward to having to re-tram the mill!
                      Thanks, Hugh
                      #56713
                      KWIL
                        @kwil
                        The nozzle arrangement is just like my paint spray gun, The size of the annulus around the fluid feed seems to be the most critical dimension in that application.
                        #56719
                        Bogstandard
                          @bogstandard
                          Glad you enjoyed making your tramming tool Hugh. As long as you did the final true up in the lathe as I did, you should find it is spot on every time. It caused such a stir when I first showed it with all the die hards with long rubber necks pulling it to pieces. But a lot of people have made them now, and they think they really help them in setting their machines up.
                          Actually Kwil, the waymine works is the outer nozzle produces the increased flow by being a rough venturi shape, and where the tip of the inner nozzle sits in relation to the outer nozzle end depends how much liquid is sucked thru it.
                          I set it up until I can just see a minute amount of cutting fluid deposited when it is directed onto my thumbnail.
                          Bogs
                          #56721
                          dcosta
                            @dcosta
                            Hello Bogs.
                            Will You be so kind as to let me know how I can find Your post about the tramming device?
                            Thanks in advance
                            Dias Costa
                            #56723
                            Gray62
                              @gray62
                              Hi Dias,
                              this is the thread I followed, I thinkit is the only one Bogs has done on the construction
                              Remember before you do the final truing up on the lathe, to take a light skim off your faceplate, I was surprised how much runout I had in mine
                              regards
                              CB
                              #56727
                              John Olsen
                                @johnolsen79199
                                Speaking of air around machines….I know a lot of people are against cleaning down a machine with air, but it is really handy for getting the packed in swarf out of those tiny torx screws on the inserts, also for any ordinary allen screws that you can’t get the key into.
                                regards
                                David Clark 13
                                  @davidclark13
                                  Hi There
                                  A spray can of WD40 is ideal for removing swarf from torx screws.
                                  regards David
                                  #56752
                                  dcosta
                                    @dcosta
                                    Hello “CoalBurnner”.
                                    Thank You for Your help.
                                    I say:
                                    Yes, I will.
                                    However in my lathe (an original Emco Compact 8) I can use the original collets and its chuck.
                                    Also the spindle nose in the Compact 8 is not machineable. It is tapered (similar to ISO 55021).
                                    Best regards
                                    Dias Costa
                                    CB
                                    t is not a matter of language, I can translate what I need.  I will close this thread as I feel I was goaded into a response..
                                    #56757
                                    Bogstandard
                                      @bogstandard
                                      CB
                                      You cannot use your collets to true it up, they might not be accurate enough. You have to do it using a faceplate as shown.
                                      A faceplate is normally supplied as an attachment, just like a chuck, and is used for clamping parts to that would normally prove too difficult to hold using normal methods.
                                      It is that final truing up that makes the tool accurate and useable.
                                      If you don’t have a faceplate, then you can’t attempt to make an accurate version of it.
                                      Bogs
                                      #56771
                                      dcosta
                                        @dcosta
                                        Hello Bogs.
                                        Thank You for Your attention to my message and help.
                                         Now I understand better Your recommendation on using the face plate.
                                        When I bought my lathe Emco Compact 8 (30 or so years ago) I postponed the buying of the face plate and when I wanted I couldn’t find it in the market.
                                        So, last year I bought an unmachined back plate with the purpose to machine it to make a face plate and postponed the project. Now it’s time to go ahead with it.
                                        And then I hope I’ll start with the tramming tool.
                                        Best regards
                                        Dias Costa
                                        P.S.: My message had some garbage after my signature I left there by accident.
                                        I’m sorry.
