Dynamos – Reversing the polarity
Home Forums Electronics in the Workshop Dynamos – Reversing the polarity
  • #358016
    Tim Stevens
      @timstevens64731
      A debate is raging locally: when changing a car-type dynamo from positive to negative earth, what needs to be altered?
      1. One view is that the output depends on how the dynamo is polarised (ie which way round the residual magnetism is) – so, no change to the wiring, just connect up to the reversed battery and close the cut-out contacts briefly (ie pulling them apart again).
      2. The other view is that either the field winding or the armature brush connections should be reversed (not both) as well as changing polarity as above.
      My opinion is that a shunt dynamo is the same as a motor, and a shunt motor will go the same way round whichever way the battery is connected, so I incline to view 1 above. And that this applies only to the dynamo, and only to one relying entirely on electromagnets, not permanent ones. In my opinion, too, changing one of the windings round is what you do to reverse the rotation, not the polarity. But I have been wrong before …
      [The whole problem is simpler, of course, if the body of the dynamo is not earthed or grounded – but those on vehicles generally are, dammit.]
      Comments, please – which view is correct?
      Regards, Tim
      Tim Stevens
        @timstevens64731
        Same as shunt motors, surely?
        #358019
        Brian G
          @briang
          I always understood the the dynamo to be self-energising based on its residual magnetism. Many years since I have done it, but this seems to agree with what I dimly remember about touching a wire to the terminal to polarise a new dynamo.
          #358030
          not done it yet
            @notdoneityet
            I’ve flashed the field coils on countless dynamos, over the years. Simple and works.
            #358034
            AJW
              @ajw
              I repolarized my dynamo by briefly energising the field coils as described. The only unit I changed was reversing the coil connections, so that the HT came out ‘+’
              Alan
              #358036
              Ed Duffner
                @edduffner79357
                I would have thought changing the magnet polarity would work, or, changing the armature or coil polarity(but not both).
                Theoretically, could Fleming's Left-hand or Right-hand rules be used to figure this out? We didn't do much with motor theory in college, so I'm not sure if the same rules apply to dynamo's.
                Ed.
                #358040
                Muzzer
                  @muzzer
                  There's no magnet in a dynamo as such, just the residual magnetism that arises from the hysteresis of the rotor (and stator), aka "remanence".
                  I suspect there's truth in both arguments but it's evidently not necessary to do any rewiring in practice, when it seems perfectly feasible to simply repolarise the rotor. I guess if you didn't, you might get a bit of an event when the regulator first connected the output up to the battery. I'm guessing that what happens – unlike an alternator, there are no diodes to prevent it trying to operate as a (starter) motor if it were left powered up, so one of the relay things inside the regulator must make the battery connection when the dynamo is up and running.
                  You can certainly use a dynamo as a motor, which is how I powered my first electric vehicle as a 9 year old. 12V car battery and a Lucas dynamo from a scrapped MG Magnette ZB, with a **** off big manual switch.
                  As you vary the current in the rotor, the voltage constant (Kv) varies which makes it possible to regulate the output current at a given speed.
                  Murray
                  #358060
                  john fletcher 1
                    @johnfletcher1
                    Both are correct but most if not all will flash the field coil. If when pressing the contacts together I always slacken off the drive belt and you can see/hear the dynamo pulley revolve as a motor.For Ed, left hand rule for motors and right one for generators. All to do with residual magnetism, hysteresis is for transformer energy loss loop. Same with car tyres. Incidentally a 12 volt dynamo make a good powerful DC motor when run on 24 volts, we used one for years lifting in/out heavy objects from a paraffin de greasing tank, the field was wired via a double pole double throw switch for up /down. Don't suppose it would be allowed today.John
                    #358061
                    Tim Stevens
                      @timstevens64731
                      Muzzer is quite right about a 'relay thing' to connect the dynamo only when it is charging. It is normally called a Cut-out, and is on its own in many pre-war cars (and some post-war cheapos) and in more modern dynamo systems it is one end of the Regulator coils.
                      Analysing the comments, it seems I am likely to be right, but some of you have doubts. So, I'll try suck-it-&-see.
                      Thanks everyone
                      Tim
                      #358072
                      Speedy Builder5
                        @speedybuilder5
                        Some car dynamos don't have their brushes perpendicular to the axis of the commutator and if reversed, do not sit properly on the commutator.
                        Paris Rhone dynamos as used on 2CV cars can't be "flashed" by holding the regulator contacts shut. You need to disconnect the field windings and flash the dynamo by connecting the field coils directly to the battery with a bulb in series.
                        #358077
                        Brian G
                          @briang
                          Can three brush dynamos (where the position of the third brush controls the output) be flashed in the same way as those with a regulator?
                          #358078
                          Muzzer
                            @muzzer
                            Posted by john fletcher 1 on 16/06/2018 15:56:28:
                            You'll have to think about that and explain what you think is the difference. All magnetic materials exhibit hysteresis and hence some degree of remanence. Can't have one without the other.
                            "Remanence or remanent magnetization or residual magnetism is the magnetization left behind in a ferromagnetic material (such as iron) after an external magnetic field is removed. It is also the measure of that magnetization. Colloquially, when a magnet is "magnetized" it has remanence."
                            #358098
                            Alan Johnson 7
                              @alanjohnson7
                              Are we debating a dynamo on a car? Or are we debating a dynamo on a small generating plant. Say 32 Volts DC? I have worked on both. Car genererator / dynamo – reverse the battery & flash the field before starting the car, otherwise you will weld one set of the contacts of the voltage regulator together. Problems: the car radio may blow up, and the ampmeter will read backwards. Depends on the age of the car. Proceed with caution!
                              #358099
                              Alan Johnson 7
                                @alanjohnson7
                                Just an afterthought……
                                I have had old dynamos that lose their residual magnetism, so they do not excite when started. Had this with a 1954 Holden motor (engine) fittd with a dynamo that was installed in a forklift. It would not self excite if it had not been used for a week or so. Solution: fit an alternator. Also in the 80's I had the same problem with small AC generating sets (3 to 5 KVa or so) made in the late 40's. They would sit on stand-by for a month, and when started the exciter would not! Basically the iron had lost it's residual magnetism.
                                #358113
                                Martin Cargill
                                  @martincargill50290
                                  On the old fashioned Lucas "standard" setup as fitted to series Land – Rovers we used to swap the vehicles from positive earth to negative earth by :-
                                  A. Swap the battery leads
                                  B, Swap the low tension connectors on the coil
                                  C, Reverse the connections to the ammeter
                                  D. Remove the D and F terminals from the regulator and take the F wire and brush it against the A terminal then replace the D and F wires.
                                  #358149
                                  Gordon W
                                    @gordonw
                                    I've always reversed dynamo polarity by "flashing" the field coil, with the dynamo removed from the vehicle. Always worked, at the time I did not really know what I was doing, but always worked. If in a car reverse the ammeter connections and coil. That's it, if uprating to 12v from 6v change the bulbs and coil, the starter will work even better on 12v. Also works on 3 brush and moving brush types.
                                    #358168
                                    john fletcher 1
                                      @johnfletcher1
                                      Off the topic, but after reading Gordon W above it brought back a few memories when my mates had Ford POP car fitted side valve engines. One mod was to fit a cylinder head from another model increasing compression ratio. making the car to go a bit faster Next do a full12 volt conversion, change polarity, but leaving the 6 volt starter in place. Now that 6 volt starter when on 12 volts really whipped the engine around, it couldn't fail to start. Happy days
                                      #358215
                                      not done it yet
                                        @notdoneityet
                                        John,
                                        That is fairly standard practice for vintage tractors, etc. Yes, the engine will usually start quite quickly. But if it does not, for some reason, the starter might get too hot that much quicker. wink
                                        Many don’t even need to change polarity – magnetos didn’t need an external power supply! Several of mine don’t even have provision for a starter motor. sad
