Posted by BB12 on 13/03/2022 14:35:39:
Posted by SillyOldDuffer on 13/03/2022 14:02:40:
Posted by Speedy Builder5 on 13/03/2022 12:40:44:
Methelated spirit ?
+1 Easier to get from DIY stores, builders merchants etc than iso-propyl alcohol.
They're about the same price, meths slightly cheaper. If buying from a UK Pharmacy the assistant might know it as 'Rubbing Alcohol' rather than iso-propyl alcohol.
I think the 99% iso-propyl alcohol is useful for other purposes too, as MikeK suggested.
I do a fair amount of electronics soldering and it is also used for many other cleaning jobs so seems like a useful product to keep in the cupboard.
Agreed. I have it for that reason. Also, depending on what needs dissolving: Acetone, White Spirit, Turps, and WD40. Meths and iso-propyl are much less likely to damage plastics than acetone, which also attacks skin a bit.
Just tested Dykem Steel Blue to see what gets it off best.
- Cutex Nail Varnish Remover (Acetone) and Carburettor Cleaner (Xylene, Ethanol & Acetone) are best. Carburettor Cleaner not recommended though – not safe in a confined space.
- Meths and IPA work equally well, requiring an extra rub to remove compared with Acetone and Carb Cleaner. The fumes are distinctly less unpleasant.
- Turps requires heavy rubbing – poor
- Strong Acetic Acid has no effect
- Dykem is close to waterproof and is oil resistant. Water and oil-based solvents are no good.
- I've run out of White Spirit and WD40. I wouldn't expect them to remove Dykem
Looking at the label reveals Dykem contains Nitrocellulose which gives it a paint-like quality. Compared with my unbranded bottle of layout blue, Dykem is smellier and takes longer to dry but produces a thick solid layer unlikely to come off when banging around the workshop.
The unbranded blue is almost certainly a simple mix of Methylene Blue dye and meths. It's thinner, fast drying, and less wear resistant than Dykem but meths quickly gets it off. Of the two I prefer the unbranded type because I mostly use layout blue to create a few reference check marks, which don't need Dykem's hard-wearing wonderfulness. (Actually I'm as likely to use a felt-tip marker as layout blue, if at all. For what I do a milling machine with DRO eliminates much of the need for layout marking…)
Edited By SillyOldDuffer on 13/03/2022 15:46:22
