This is a follow up to a previous posting about overloading a Chester Champion V20 Mill: http://www.model-engineer.co.uk/forums/postings.asp?th=86758&p=1
In the absence of any information from the trading company (Chester Machine Tools) about a duty rating for the Champion V20 Mill ("It is hobby rated and not for extended use"
, I did some temperature measurements today, both on the control box and the motor. Stick-on temp gauges were affixed to the outside of the control box, and directly to the motor.
The first interesting result is that the control box did not reach 32 C during any of the tests ( ambient was about 20 C I guess), so any previous overloading of the control board was probably not temperature related. So for the moment I won't worry about cooling the control box and assume the previous control board failure was a one-off.
The measurments on the motor were even more interesting and contrary to the experience of some people on this forum. In essence the problem is with high motor speeds and apparently NOT low motor speeds.
Temperature was measured in the range 32 to 40 C ( in one case to 49 C) under NO LOAD condition, with various gearing and spindle rpm settings. All tests were made with the motor cover in place.
Interestingly this shows that at slow motor speeds the motor temperature goes up slowly and then stays at the same temperature.
However at high motor speeds, the temperature goes up rapidly and keeps going up – I stopped measuring at 49 C in one case! In the case of the HIGH gear setting at 2500 rpm on the milling spindle, the temperature went up 17 degrees C in 12 minutes. All of this without any load. And it then takes a whole hour before the motor temperature comes back down to 32 C – and that is with the motor cover taken off.
So at higher speeds the amount of heat generated cannot be dissipated so the machine doesn't settle down to a stable tmperature. No wonder the trader didn't want to publish a duty cycle, it would be something like 'Use for a couple of minutes, then leave to cool down for an hour'.
Passive cooling would be the preferred first solution (the Mill is still under warranty) and clearly the current motor cover prevent this, so I will take some more measurements this week with the motor cover removed.
Here are the measurements:
LOW gear – Milling spindle at 500 rpm
0 mins – 32 C
2 mins – 33 C
4 mins – 33.5 C
6 mins – 34 C
8 mins – 35 C
10 mins – 36 C
12 mins – 36 C
14 mins – 36 C
16 mins – 36 C
LOW gear – spindle at 1500 rmp
0 mins – 32 C
2 mins – 34 C
4 mins – 35 C
6 min – 36 C
8 mins – 38 C
10 mins -40 C
HIGH gear, Milling spindle 500 rmp
0 mins – 32 C
2 mins – 32.5 C
4 mins – 33 C
6 mins – 33 C
8 mins – 33.5 C
10 mins – 33.5 C
12 mins – 33.5 C
14 min – 34 C
16 mins – 34 C
18 mins – 35 C
20 mins – 35 C
22 mins – 35 C
24 mins – 36 C
26 mins – 36 C
28 mins – 36 C
30 mins – 36 C
HIGH GEAR – Milling spindle speed 1500 rpm
0 mins – 32 C
2 mins – 33.5 C
4 mins – 35 C
6 mins – 37 C
8 mins – 39 C
10 mins – 40 C
12 mins – 42 C
HIGH GEAR – Milling spindle 2500 rmp
0 mins – 32 C
2 mins – 34 C
4 mins – 36 C
6 mins – 39 C
8 mins – 41 C
10 mins – 47 C
12 mins – 49 C
