durham and north yorkshire cylinder fixings
Home Forums Website Questions, Comments, and Suggestions durham and north yorkshire cylinder fixings
  • #376209
    David Bothwell 1
      @davidbothwell1
      Does anyone know the size of the fixing bolts (to the boiler) on the 2" Durham and North Yorkshire traction engine? Also what would be the "best" material for the same? I suppose a similar engine could provide similar info?
      David Bothwell 1
        @davidbothwell1
        fixing bolts or studs for the Durham
        #376226
        BC Prof
          @bcprof
          My plans show No 26 holes in the cylinder for the boiler fixing studs so this gives and upper size for the studs of 3.7mm . I used Bronze for the studs on my Burrell Brian C
          #376231
          BC Prof
            @bcprof
            Having engaged brain I went out to the workshop (AKA Tip ) and found one of the spare studs . It seems that I used 4mm rod. Brian C
            #376236
            David Bothwell 1
              @davidbothwell1
              Hello Brian most helpful, many thanks for your posts
