Dual voltage 3 phase wiring
Home Forums Electronics in the Workshop Dual voltage 3 phase wiring
  • #493776
    Richard Cox
      @richardcox82602
      evening all
      quick question I have a three phase compressor that has been running off a 230v three phase inverter the motor was configured in delta, I’m lending it out to someone who has three phase on site, do I just swap the terminals to star configuration,
      i guess what I’m trying to ask is dual voltage motor
      if 415v then motor should be configured in star
      if 230v then should be configured in delta
      regards Rich
      Richard Cox
        @richardcox82602
        #493779
        Emgee
          @emgee
          Configure to High voltage by swinging the links over, make sure he has a suitable starter but you don't mention HP.
          Emgee
          #493784
          Richard Cox
            @richardcox82602
            Hi emgee
            it’s a 5.5hp no starter, so the u2 v2 w2 should all linked with the busbars/straps And the u1 v1 w1 should have the phases connected
            Rich
            #493797
            Emgee
              @emgee
              Hi Richard
              Best to use a starter with any motor, especially that size if running at 3 phase 415v, or better still leave it delta connected and send your inverter which hopefully has some fault and overload protection on the output.
              Emgee
              #493804
              Steviegtr
                @steviegtr
                Posted by Richard Cox on 01/09/2020 22:16:23:
                Hi emgee
                Rich
                Yes. But do not just rely on an isolator for switching. They are not meant for that.
                Steve.
                #493809
                Richard Cox
                  @richardcox82602
                  Hi Steve
                  it will utilise the pressure switch on the compressor for stopping and starting
                  Rich
                  #493897
                  Steviegtr
                    @steviegtr
                    Posted by Richard Cox on 02/09/2020 08:40:05:
                    Hi Steve
                    Rich
                    yes
                    Steve.
