Posted by Bill Davies 2 on 04/07/2023 17:09:09:
…. As an inspector, I used long travel plunger type dial clocks for checking tooth size on gear shaper cutters. The lever-types were used for comparing close to the zero reading.
Bill
I'm hungry for more on how Inspectors work please Bill. I know a bit about practical home measurement and fitting, and have an interest in Metrology, but there's much I don't know about the how, what, why, and when of inspection. I'm sure there's more to it than haphazardly poking stuff with a GO/NO-GO gauge. Might make a good MEW article – Neil's looking for new material.
For example, within tolerances, even a simple hole has to be made in the right place, with the correct diameter, and depth, straight, circular from end-to-end, and with a given surface finish. In my workshop, drilling is often imperfect, with holes off-centre, not perfectly round, veering off axis, tapered, depth off, and scratched. Mostly doesn't matter because what I do rarely needs better than about 0.05mm.
How would an Inspector check a Duffer built part, say 7 off 5mm holes drilled 10mm deep on an accurately centred 100mm diameter PCD, all dimensions within ±0.005mm?
