DTI Dovetails?
DTI Dovetails?
Home Forums Beginners questions DTI Dovetails?
  • #50736
    Chris Trice
      @christrice43267
      On the basis that no question is too stupid, on both  the DTI’s I own, the bodies have slotted dovetails, presumably for mounting in an appropriate dovetailed fitting but I can’t find any information on the fittings or how they’re mount onto a lathe/mill. Fortunately both come with a little black arm I can fit into the toolpost of the lathe and there’s a stem at the top which I can mount in the chuck/collet of the milling machine but I was curious to the use of the dovetail and if it’s worth investing in the extras?
      Chris Trice
        @christrice43267
        #50737
        chris stephens
          @chrisstephens63393
          Hi Chris,
          I assume your DTI’s are Verdict, if so go to the following link which will show you a page from their catalogue.
          chriStephens
          #50759
          Circlip
            @circlip
            A little “Attatchment” for you to make and worth the effort
              Use HE30 or 6082 for the material
              Regards  Ian
              THIS link works Chris.
              Oh yes, if you machine it correctly, you don’t need the 1.3″ long slot in the bottom left hand view.
            Edited By Circlip on 16/04/2010 12:33:21
            #50784
            Chris Trice
              @christrice43267
              Thanks guys. Yes, they are Verdict DTI’s so both links are quite relevant. If you copy and paste that first link, it works fine. Thanks again.
