Posted by Daniel Brannan on 09/05/2019 17:38:57:
According to this there is a design flaw with the bearings on my model although I can't really see how the lead key would affect anything regardless of fit as the bronze bearing is pulled into the head stock as you tighten and would surely stay in place as a result. Has anyone else had any experience of chatter with this model?
http://www.lathes.co.uk/drummond-headstocks/
Not with that particular model, but all lathes chatter, and you just adjust your cutting style until they stop.
lathes.co.uk describe a problem that Drummond tried repeatedly to fix so I guess you have a machine more likely to chatter than others. Provided it's not also worn elsewhere such that the whole machine is loose, it should still be capable of good work. Just don't expect to hack metal off in grand style.
An important feature of machine tools is their rigidity. Apart from your bearing issue, gentlemanly treadle lathes tend to be flimsy compared with machines designed for a hairy bottomed motor. When you get the old girl going, treat her gentle and see how far you can go before chatter intrudes. Don't be surprised if getting the best out of the lathe takes time, practice and sharp cutting tools.
Edited By SillyOldDuffer on 09/05/2019 17:55:57
