Drummond enthusiast
Drummond enthusiast
  • #399695
    Lee Rogers
      @leerogers95060
      Hello all. I'm into all things Drummond Brothers lathes and tools. It all started as an offshoot from aero modeling and tool making for larger projects in Alluminium. I have recently restored a B Type Admiralty lathe , I now have 3 1/2 of them. 2 complete and the rest in crates. An Amolco benchtop mill and a modern Optimum pillar drill. Always interested in hearing about small old lathes and other ancient machinery.
      Lee Rogers
        @leerogers95060
        #399712
        Hopper
          @hopper
          Welcome to the forum. You are in good company. There is a number of Drummond owners on here. I have 1937 M-Type that still gives good service and is a pleasure to use.
          #399717
          AJW
            @ajw
            Good to hear they are being used/saved!
            I restored a1918 M type for my son who gets a lot of use out of it. It had been stored for decades and once all cleaned off (not rusty) most of the surfaces still had the original scrapping marks – it was like new. I motorised it with 1/3hp motor but it still used a flat belt for headstock..
            As.Hopper says there's quite a few used on here.
            Alan
            #399727
            Hopper
              @hopper
              I use a modern poly-V belt run straight on the old flat pulleys to drive mine. Works a treat with the big 1/2hp motor.
              #399731
              Nick Clarke 3
                @nickclarke3
                My long term restoration project is an early round bed – got a seriously overlarge 1HP 3 phase motor for almost nothing so it will run from that through a vfd/inverter.
                Overkill, but what was available at the time.
                Scheming out a countershaft. It has already had a v pulley fitted when I got it so the poly vee option is not the first choice unless a flat pulley, or two, turns up.
                #399735
                AdrianR
                  @adrianr18614
                  Hello,
                  I have a B type with a worn bed that i have had some luck scraping and, a worn lead screw that has had the nut filled with white metal. So I can only get about 12" travel on the saddle. Apart from that it runs well.
                  Have you seen the Drummond Lathe Group on Yahoo?
                  #399737
                  David George 1
                    @davidgeorge1
                    Hi Lee welcome to the forum. M type Drummond again. Just started a rear toolpost for mine and have acquired a set of castings for a tumbler reverse as well.
                    David
                    #399747
                    roy entwistle
                      @royentwistle24699
                      I have a Drummond hand shaper It would be nice if I could change hands occasionally
                      Roy
                      #399801
                      JC54
                        @jc54
                        Hello Lee, as you will already have seen there is still quite a "Drummond" following. I have a "roughly" 1906 5inch split bed and a highly modified 1947/8 M. The accuracy of the lathes is definitely better than minethinking. Welcome to the forum. John
                        #399836
                        Hopper
                          @hopper
                          Posted by roy entwistle on 11/03/2019 16:06:39:
                          Roy
                          Saw a pic on here recently of one that has been motorized and it looked like quite a handy unit. (oooh bad pun! Totally unintentional I promise.) Then you could follow this months MEW and add CNC control.
