DRO question.
DRO question.
Home Forums Workshop Tools and Tooling DRO question.
  • #179024
    Nick_G
      @nick_g
      What is the difference between the 'Incremental' and the 'absolute' settings on a DRO. And when should the different modes be used.?
      Cheers, Nick
      Nick_G
        @nick_g
        #179029
        Paul Lousick
          @paullousick59116
          In absolute mode the position shown on the DRO is measured from the datum that you used at the start of your project. Incremental mode allows you to position the cutter from a secondary position (eg. from the hole which you have just drilled). DRO's allow you to have Incremental datums to allow you to measure from many secondary datums but allow you to always reference back to the main (absolute) datum that you used at the start.
          A good explanation is shown on Youtube by Easson DRO's at
          Paul.
          #179154
          Nick_G
            @nick_g
            Many thanks for that Paul. I shall have a nosey.
            Cheers, Nick
