I must admit I have never even thought in absolute / incremental terms, as I prefer to work from datum points or edges, so just set to those and press the appropriate ‘0’ buttons.
My DRO set on the mill is a Machine-DRO one, is reasonably easy to use although switching between inches and mm seems to need the thing switching off, pasuing then switching on again. (On the unit, not the mains socket.) Nor have I really explored its funtcions beyond straight meausurements.
However, its operating manual is clearly-written and makes sense! So perhaps I have missed something in the book, about that units-conversion.
Electronci equipment should not be so enclosed it may overheat, but I have draped a sheet of ‘Cellophane’ or similar loosely over the DRO unit to protect it from dirt including my oily fingers. (The workshop calculator is in a Polythene bag for the same reason.)
Pete –
I am a bit puzzled by:
With milling you are generally less interested in how accurate the measurements are.
Umm, I am! My model-engineering will never win prizes but I do like bolt-holes to match, square bits to be square and sliding bits to slide. Essentially there should be no difference in accuracy between absolute and incremental settings; but on the odd occasions I create real drawing I always use absolute dimensioning unless another approach is better… so not often. (Accuracy or precision? I never remember the difference.)
If Hole B is 1.00″ from Hole A which is 0.25 from the edge, I move the work to the indicated 0.25″ then 1.25″ , from the edge. Not 0.25″ then set the indicator to 0.000 and move 1.00″ from there, whether dial or digits. Either way, A and B are still 1.00″ apart. If they aren’t it’s ‘cos I’ve cocked it up, not by the technique being wrong.
There are times when Hole A (or B) should be the datum, particularly in rotary-table work, but those are not common.
I believe we need consider how we use the DRO (or dials!) with respect to the drawings we are using.
I suspect most model-engineers work from purchased drawings for their main projects, and these may influence the choice of DRO use. The dimension styles on older designs can be poor, with all sorts of chains (incremental in a bad way), back-and-forth dimensioning, umpteen-sixtyfourths-inches even for wholly-turned parts, and no datum edge or corner selected for millers’ convenience.
I gather some people resort to re-drawing the thing so it is dimensioned correctly for their methods of making. This is fine and can flush out original errors, but adds another miscalculation risk layer so needs considerable care.
So there may be occasions when the absolute / incremental argument is not very helpful; and then it is to the machinist’s judgement how to approach the work.
In the end we hope the different components unite and work properly. Holes A and B in one part should match their other-halves in the other part straight off the mill; the DRO system should help us achieve their blissful union!
