DC31k
You’re a genius!
Thanks for the comprehensive reply, allow me to explain……….
I had suspected ages ago that my DRO was the same generic model as the Chester one (Quark) that you provided a link to so had downloaded the manual. Unfortunately though the stated sequence for resetting parameters didn’t work for my machine so I assumed there was a small difference in the two.
It turns out that the Quark pdf manual tells you to press the “9” button during boot-up to enter the parameter menu – which is what I had tried countless times without success (along with lots of other buttons). As you quite correctly state, the button to be pressed is “6” NOT “9”.
Looking at the manual with a critical eye reveals why the manual is wrong.
Instead of simply using the “6” character they’ve used an image inserted into the pdf of the actual button – but it’s been inserted upside down thus reading “9”.
So all is now back to correct configuration.
Many thanks for your excellent advice.
Ken
