Just did a 200mm x 5mm one a week or two ago in 40mm steel
Came in from each end and it was slightly out for a push rod so will have to ream the middle
Take your time and use good drills and plenty of lube and lots of clearing out, swarf is your enemy
You can HEAR and feel by hand if a long drill is going on the wander, you can also test them by eye before drilling since the point and shaft should be rock steady when it spins and you should be able to spin the inserted drill with your fingers with minimal resistance
I used a 6mm mill to flatten the spindle face, then a 7mm long spot for a good start, then a good normal size, then a good extended drill
Will hunt for a long 5mm file to ream gently
Always a bit twitchy when that eureka moment is coming, even if you know its gone well
350 mm is a lot, lol
GL
Edited By Ady1 on 12/06/2020 07:30:42
