drilling tool steel
drilling tool steel
Home Forums Beginners questions drilling tool steel
Viewing 15 posts - 1 through 15 (of 15 total)
  • #612030
    capnahab
      @capnahab
      I need to drill a 40 thousandths hole in a piece of 1/16 piece of silver steel. The hole dimension isn't critical. Presumably I need to anneal it but any pointers to colour and length of time and treatment afterwards greatly received.
      capnahab
        @capnahab
        #612034
        Robin Graham
          @robingraham42208
          If the silver steel is 'as bought' it will be in a 'soft' state, no need for any heat treatment before machining.
          Robin.
          Edited By Robin Graham on 01/09/2022 21:52:04
          #612035
          Dave S
            @daves59043
            Silver steel is normally sold annealed, then hardened after machining.
            however if hardened can also be drilled using carbide drills.
            How deep is the hole, or is it cross wise?
            noel shelley
              @noelshelley55608
              1mm will do then ! A good quality drill bit will do it, if not then carbide. Tracy tools for the bits ! Noel.
              #612039
              capnahab
                @capnahab
                Its a cross hole and a brand new dormer drill wouldnt touch it so i think it will need annealing.
                #612041
                Anonymous
                  Can you mark the silver steel with a file? If yes then it isn't hardened, if not then it is hardened. To anneal heat to 800C and let it cool naturally.
                  I suspect that the silver steel isn't hardened and that the problem is with the drilling technique. Trying to drill a cross hole in 1/16" rod is an invitation for the drill to wander. The hole needs to be started with a stiff drill, preferable stub and carbide. My go to supplier for drills is Drill Service.
                  #612046
                  capnahab
                    @capnahab
                    I wonder if it’s piano wire ..
                    #612059
                      If it is piano wire then do you really need it to be piano wire or can you change to silversteel as Piano wire is almost impossible to get back to it's hard state as the "patenting" process is not something that can really be done at home.
                      Same test as has been suggested for the Silversteel, can you easily file the end of the piano wire (use an old file)
                      #612076
                      Old School
                        @oldschool
                        I use piano wire in quite a few applications it came from the local model shop. It can be drilled and tapped with care drilling not too fast and with lubricant and good quality sharp drills, taps also need to be sharp and lubricated.
                        Have successfully made “D” bits out of piano wire and hardened and tempered them with no problems.
                        #612078
                        Brian Wood
                          @brianwood45127
                          Would spark erosion be an alternative method ?
                          #612079
                          jaCK Hobson
                            @jackhobson50760
                            if silversteel, then just a high temper should make it soft enough to drill. In a dark room, heat until it just starts to glow… or stop just before at 'black heat'.
                            This won't work with all 'tool steel' particularly deep hardening steels, stainless steels, air hardening, HSS etc.
                            I think this ability to easily get the steel back to a workable condition is a major reason for choosing water hardening steels for small tools i.e. easy to re-work if you get it wrong first time or need to adjust.
                            Edited By jaCK Hobson on 02/09/2022 10:22:10
                            #612084
                            Alexander Moss
                              @alexandermoss
                              If you are trying to drill near the end of a silver steel bar that may be hard from the grinding used to cut the rod during manufacture. That is why silver steel bars of nominal 12 inch length are or were slightly longer, so you could cut off the ends with a hacksaw and discard them.
                              Roy Moss
                              #612094
                              bernard towers
                                @bernardtowers37738
                                Thought I’d have a go and see if it would work, used a piece of 1/16 silver steel and a bell centre drill with a 0.5mm tip then followed up with a 1mm drill and looks ok. Work was done on a peatol with a cross during jig at 4500 rpm.191efbb8-24f6-4d8f-a42d-28d7d2e1cc91.jpeg
                                #612142
                                capnahab
                                  @capnahab
                                  cheers old school.
