Drilling straight
Drilling straight
Home Forums Beginners questions Drilling straight
Viewing 2 posts - 26 through 27 (of 27 total)
  • #620317
    Huub
      @huub
      If you are using a mill, then check if the mill quill is square to the table. You can do this by placing an indicator in the chuck and measure a square object. A 1,2,3 block or an angle block. Measure on both sides (X and Y).
      edit: Checkout this video: https://www.youtube.com/watch?v=asmH4HjZLRY
      Edited By Huub on 08/11/2022 22:45:58
      Edited By Huub on 08/11/2022 22:48:12
      Dell
        @dell
        I drill down to 0.3mm and although it’s a pain I always drill brass with a doctored drill for brass because when it bites it can pull the drill bit to the side it bites, I have a separate set for brass.
        Dell
