I use a totally different method which completely removes the risk of breaking a tap in the main casting.
I machine some short brass bushes with a tapped hole in the centre to suit the screws used, in my case they were Metric 1.2mm ones, and made in a batch on my watchmaking lathe.
Then simply drill a hole for the bush to fit where you need the screws to go in the casting, and either press fit or loctite them in position.
Worst that can happen is you break a drill or a tap in one of the bushes, but just throw that one away and make another.
From memory I think it might have been Graham Meek who put me onto this method.
Phil
