Drilling sliding scales
Home Forums Model Engineer. Drilling sliding scales
  • #37564
    Terryd
      @terryd72465
      Terryd
        @terryd72465
        Hi all,
        I am about to fit a new vertical scale to my milling machine and need to drill the scale to connect to the quill. Is there anything I should know before starting, will normal HSS drills do the job?
        Thanks in advance
        Terry
        #102592
        Douglas Johnston
          @douglasjohnston98463
          I did this a while ago and found that a HSS drill was no good. I ended up using a solid carbide drill and this proved to be ideal. You could use a clamp type fixing which would eliminate the need to drill the scale.
          Doug
          #102597
          Terryd
            @terryd72465
            Hi Doug,
            I may go down teh clamping route initially. Thanks for the information.
            Best regards
            Terry
            #102611
            colin hawes
              @colinhawes85982
              I think you ought to forget drilling scales when clamping is perfectly adequate. Colin
              #102624
              Ian P
                @ianp
                I have had no problem drilling the common 'stainless' Chinese calipers with ordinary HSS twist drills, in fact I have tapped M4 threads into them as well.
                When drilling you need to apply lots of pressure so that you can take a good cut rather than letting the drill rub.
                Ian P
                #102625
                Michael Cox 1
                  @michaelcox1
                  I also had no problem drilling cheap Chinese digital caliper using HSS drills. It cuts easily with a hacksaw. As Ian said maintain a good pressure to prevent work hardening.
                Home Forums Model Engineer. Topics
