Some of my engineering offcuts were pretty hard, tempered/semi-tempered.
Carbide was the only material happy to chomp through the tough bits, and good lathe stiffness is essential whenever possible.
I would try a boring bar with a carbide tip fitted like a flat drill bit.
You’ll probably have to modify an old boring bar or make your own.
It also sounds to me like you’re using too high a speed, so all you will do is heat harden an already hard material.
High torque, low speed, mounted on a good stiff toolpost and shove it in there, don’t be shy.
Curiously, I find that “blunt” carbide can work well with negative rake on the really tuff bits.
it’s amazing stuff if your machine is stiff enough.
Whatever solution you find, carbide tooling will make life miles easier.
And don’t go buying expensive gear until you get a feel for the job, unless yer rich.
Edited By ady on 10/11/2010 11:23:04
