Drilling in 60HRc
Drilling in 60HRc
Home Forums Beginners questions Drilling in 60HRc
  • #332537
    Martin Dowing
      @martindowing58466
      I have few solid carbide TiAlN coated spot drills (90deg.)
      Are these suitable to crossdrill a hole in hardened bar, 60HRc, (of course a little flat will be ground to aid start of the hole).
      If so, what speeds would be suitable for 3-4 mm spot drills @ 60HRc job?
      How many holes each drill could produce before call for regrinding or retiring?
      Martin
      Martin Dowing
        @martindowing58466
        #332562
        Brian Wood
          @brianwood45127
          Hello Martin,
          As no-one else has ventured a suggestion, I can report that I have drilled holes in hardened steels with masonry drills using a diamond sharpened tip. Whether you can still get them in the size you talk about I don't know and the life before needing sharpening is not very long.
          Slow speed, heavy loading on the drill and coolant should get a result
          Regards Brian
          #332590
          David George 1
            @davidgeorge1
            Hi Martin I have had poor results drilling in this hardness steel what material is it as if it is a tool steel you win probably not succeed but if it is silver steel or GFS you may but I have resorted to spark erosion at this hardness there may be someone near you that can spark out a hole using a copper electrode. Also what depth are you drilling.
            David
            #332612
            Chris Evans 6
              @chrisevans6
              Sometimes it is doable but I can tell you from experience broken carbide in a job is a bugger to spark erode out. If it is a through hole try and find a wire eroding company that has a start hole machine and get the hole wire eroded. They will be able to hold a very good size.
              #332641
              Martin Dowing
                @martindowing58466
                Material is a ground bar for linear bearings of Cf53 steel, 8 mm diameter and induction hardened to depth of 0.8 – 1 mm. So it is really a deep case hardening.
                Specified hardness is 60+/- 4 HRc. Crossdrilled hole would be through.
                @Brian – Thanks for hint. Will try it – cheap enough.
                @David and Chris – I have to look around for someone with spark eroding facility.
                Martin
                #332646
                Samsaranda
                  @samsaranda
                  Recently had to open an 11.2 MM hole to 12 MM, the object in question was a quick change tool post, it was hardened steel, not sure what hardness but bloody hard. I tried 12 MM cobalt drills but gave them up after wrecking 3, then found that a 12 MM diamond core drill as sold by Arceurotrade managed the job not quite like a knife through butter but at least it made it through. I would suggest that you probably will need some sort of diamond cutting tool.
                  Dave W
                  #332655
                  John Reese
                    @johnreese12848
                    Drill through the case hardening using a carbide die drill. Turn the shaft 180* and drill through the case on the other side. Use HSS drill to drill out the remainder.
                    #332676
                    Chris Evans 6
                      @chrisevans6
                      Now we know it is linier shafting you will be fine with your small flat and drill to start the hole. I would not use the spotting drill to go all the way due to lack of any side relief.
