Drilling Holes in copper tube
Home Forums Materials Drilling Holes in copper tube
Viewing 15 posts - 1 through 15 (of 15 total)
  • #154651
    Martin Walsh 1
      @martinwalsh1
      Hi
      I'm making a small boiler 2 Inches dia
      and I need to drill 3 holes 3/8 dia
      what is the best way to do this. As I have
      heard drilling holes in copper is a nightmare
      Thanks
      Best Wishes Martin
      Martin Walsh 1
        @martinwalsh1
        #154660
        MadMike
          @madmike
          I would suggest either a 3/8 dia hole saw/tank cutter or trepanning the holes.
          #154661
            The stepped drills work quite well or use successive sizes of milling cutters say 1/4" drill then 5/16" and 3/8" milling cutters
            #154668
              +1 for step drills.
              Aldis often sell them at stupidly low prices, but always in metric sizes.
              I don't think you'll find holesaws or trepanning cutters down to 3/8".
              If you are brazing bushes in the holes, you can [probably get away with using a cone drill. Otherwise, drill undersize and file to a good fit on the bush.
              FMES
                @fmes
                These work very well Martin **LINK**
                #154677
                John Baguley
                  @johnbaguley78655
                  +2 for step drills. Centre drills work well as well.
                  Niloch
                    @niloch
                    +3; 'have drilled 84 x 12mm & 2 x 20mm holes in 10SWG copper with this
                    #154758
                    Ian S C
                      @iansc
                      I have not got a photo of one. similar twist drills are sold for wood working, the end is ground so that the centre is a spur point, and the outer dia., is the point that cuts the hole, ideal for drilling sheet metal, no more triangular holes. It's easy enough to grind up an ordinary twist drill. Ian S C
                      #154770
                      Roger Woollett
                        @rogerwoollett53105
                        Assuming that the holes are in the flat end plates of the boiler iether a step drill or a cone drill will work fine. The sort of drill Ian S C describes are sold as bullet drills. They also work fine.
                        Roger Woollett
                        #154846
                        Ian S C
                          @iansc
                          I got taught to grind them when I was on an apprentice course at NAC(National Airways Corporation) This was before the days of Air New Zealand. Our airframe instructor learned of the drill type during WW2.
                          Ian S C
                          #154885
                          Robert Dodds
                            @robertdodds43397
                            Martin,
                            Just producing three holes doesn't justify spending a lot of money but in another age I used to use "slow helix drills" to produce holes in the copper pipes for urinals. Burrs on the inside from break through were not encouraged (you get sprinkles down the trouser leg) and the slow helix reduces the tendency to grab the thin wall copper tube.
                            Not being sure if they were still produced I googled and then stumbled on this site from Tomsk University http://portal.tpu.ru:7777/SHARED/p/PRONINA/documents/files/f9.pdf
                            Its set out like a tutorial but theres lots of relevant info in it
                            Bob D
                            #154914
                              These might help you get started:
                                Posted by Martin Walsh 1 on 07/06/2014 13:50:40:
                                I'm surprised to see that no-one has yet suggested
                                3/8" milling cutter [preferably 3-flute]
                                … which seems the obvious choice, to me.
                                julian atkins
                                  @julianatkins58923
                                  i think you are all making things far too complicated!
                                  i drilled 14 holes each end in my current boiler project for 3/8" dia tubes, opening up in steps to 23/64" dia then reaming 3/8" dia, using ordinary drills. i have drilled and reamed another 8 of same size for boiler bushes and a further 3 of 7/16" dia same method.
                                  slow speed, and a bit of WD-40 sprayed on during same.
                                  cheers,
                                  julian
                                  Edited By julian atkins on 11/06/2014 00:06:12
                                Home Forums Materials Topics
