drilling holes in axleboxes
Home Forums Beginners questions drilling holes in axleboxes
  • #48106
    Nigel Hyde
      @nigelhyde97004
      Hello
      I am revamping an old chasis and i need to replace the axleboxes.
      This loco does not have horns, but the axleboxes run on the frames, so i made the  new boxes all the same and filled the frames to fit
      Do i need to make a jig to drill and ream the hole or would it be good enough to set them up in the four jaw?
      how do you all do it?
      Thanks
       Nigel
      Nigel Hyde
        @nigelhyde97004
        #48117
        Circlip
          @circlip
          Are the cutouts in the frames true and square?? If so, why not the 4 jaw?? DON’T make the holes too tight, the loco will bind on corners.
            Regards  Ian
          #48119
          Phil Ashman
            @philashman88468
            I used a simple jig to determine the axle centres, to ensure that they were the same on both sides of the loco. The same jig was then used to determine the centres in the coupling rods, because if they’re not exactly the same, the rods will bind. Having got the centres, the boxes were bored in the 4-jaw.
            Phil
