Posted by Kiwi Bloke 1 on 10/04/2017 10:19:17:
They say that the biggest fool can easily ask questions the wisest man cannot answer, so I feel no shame asking this…
What is the recommended technique for drilling holes? No, that's not really the question. What's the scientifically correct way to drill holes, and why?
It's often recommended that holes are drilled, using a succession of progressively larger diameter bits. The diameter increment is usually glossed over. OK, doing this reduces the load on the machine (and workpiece), but it has disadvantages. The major one is the difficulty of getting the 'next size' drill to centre, and not try to start to drill a pentagonal, or other non-round hole (for the well-understood reasons). If you ram the bit into the hole, to get it into cut without it dancing all over the place, the sudden load on the bit's corners can break them off.
I tend to drill in only two steps: first, a small pilot hole, around the same diameter as the final drill's web thickness, then the 'finished' size, but I have fairly grunty machines available.
So, what do you do, and why?
The drill essentially has a spade/chisel tip form, it's the appropriate shape to facilitate cutting, much in the same way that other tools need to come to a sharp point or have the correct clearance angles in order to shift material.
The shape of the spiral flutes is merely to carry away as much swarf as possible without jamming in the hole, they could be straight if they wanted to but they spiral them because this shape allows more room.
You're right about using a bigger drill in a hole nearly as big; they don't cut a perfectly circular hole over another one, in order to do this properly, you need a reamer or a core drill, no i'm not talking about hole saws, these are 4 or more flute drills, which do not come to a sharp point, they are solely designed for opening up a smaller hole, they are quite rare and relatively expensive to buy.
I agree that so long as the pilot is a small hole, this can be rather useful for large diameter holes, However, it would be wise to make sure that you don't cut away the counter sink of the centre drill with your pilot drill, as this is what helps your final size drill to centralise properly as it begins the hole.
An important point for lathe drilling that I have put elsewhere, don't move the tailstock through a hole to attempt to drill a longer hole. Always drill from a single fixed position because otherwise the hole will start to go off centre.
Unfortunately this means you'll need to either change to a longer drill part-way through the drilling cycle or use a boring bar to finish. (if a hole longer than the travel of your quill is what you're looking for)
Michael W
Edited By Michael-w on 10/04/2017 10:49:38
