Drilling copper
Drilling copper
Home Forums Workshop Techniques Drilling copper
  • #99600
    Bob Perkins
      @bobperkins67044
      I need to drill quite a few 0.8mm holes around a 70mm 2 3/4" 16 swg copper tube. Any advice on speed, coolant drill type welcome.
      Thanks
      Bob..
      Bob Perkins
        @bobperkins67044
        #99609
        JohnF
          @johnf59703
          Hi Bob, Buy a new pack of HIGH QUALITY HSS drills — don't economise buy a top brand e.g. dormer or similar. Speed— probably as high as you have on your machine but not knowing what machine you have I may be wrong?
          For lubricant I would use suds if you have it if not soapy water works well but clean and oil your machine after.
          Another one I have read about but never tried since I read it is milk — might be worth a try.
          Good luck John
          #99612
          julian atkins
            @julianatkins58923
            gosh 0.8mm is small! i would be inclined to use a smaller drill first, and deburr on the inside after, then drill through 0.8mm. i use WD-40 or similar (paraffin alternatively) for drilling copper. there is an ideal drill angle for copper, but you wont be able to do that for a drill of that size by way of re-grinding. not too fast.. not as fast as say drilling brass that size.
            good luck!
            cheers,
            julian
            #99613
            DMB
              @dmb
              If you use milk, you need to have a good clean up – nice to drink cold but out of date, rank + stinking!
              I think even a small amount left on machine will probably stink.
              I have used (not for copper) excess oil drained from tinned sardines but that goes very smelly fishy pong. Live + learn!
              good luck,
              Clive Hartland
                @clivehartland94829
                Lard is good, will be easy to clean off as well.
                #99625
                Bob Perkins
                  @bobperkins67044
                  Would a two flute end mill or PCB type drill with a larger shank be more suitable?
