Thanks,
I have had few drill chucks and developped sort of love-hate relationship to them. They look like they are up to anything, but I think that for each aplication there is a better alternative.
I don’t have a turret either and I had to make some brass knobs. They needed a thread and a countersink. Tried with a chuck, but tap didn’t hold well. Then I used three ER25 collet each with it’s own nut and drill/tap/countersink! Lucily I had some spar nuts!
I got a special chuck for taps. Big and ugly but works.
I haven’t developped a “knack” for reamers yet, I hold them with a tap-wrench and tail stock holds the tap with a centre. I either need to grow more hands or build a floating holder for a reamer. Tried with a chuck – I tought that it’s close to centre, it is for everything elese, but not reaming.
Larger drills seem to be happier on MT socets anyway.
But I still use a chuck for a bench drill and most of the drills on the lathe anyway! And the good news is that it works good enough most of the time! Anyway, if there is any swarf on the drill, cheap chuck does not moan as loudly as collets do!
I’ll try some Röhm “prima” chucks on the smaller size (keyed) and got one used milling machine chuck that is pretty massive for it’s nominal capacity, This should give me some perspective.
I’ll be saving for a better keyless chuck, the only real consideration is size:
*up to 13 mm (95%+ big eneugh, but I have some larger drills)
*up to 16 mm (But I have too smaller drils that these will hold….)
All pretty much same quality chucks:
* LLAMBRICH SPX
* Röhm 134 Spiro
* Albrecht Precision Keyless Drill Chuck
Cost close the same, then again there is Röhm 136 “Supra and such Jacobs chucks that probably would give most bang for the money and probably would be good enough. I’ll see after next salary.
I wish I knew what I need, instead of what I want (Albrecht will allways win on last case and I don’t think it fares bad on first either….)
RGDS,
PekkaNF
* my speller has dystolexicon
Edited By PekkaNF on 14/12/2010 20:37:54
