Thanks for all the replies folks – much appreciated.
Versaboss: The 1500 was only for the finishing "spring" cuts when all else failed to remove the ridges.
It was a 2mm boring bar that gave me the ridges. New insert. Lots of lube.
But I don't recall the normal cutting speed I used – so one way forward is to try again at about 150rpm. Thanks.
Martin. Yeah. Thanks.
Ian: OK I googled "back gear". I don't have one.
However, I think getting them hot was a problem.
I did go up through the drills as you mentioned, though some of the Youtube boys don't and it seems to work fine for them.
On the last hole like this I drilled the 20mm drill's shank was binding in the hole near the chuck. I reduced it with emery but I still had to fudge a worrying bar arrangement to stop the tailstock spinning. It got the job done but it wasn't a happy experience.
So – maybe buy some more Blacksmiths drills and watch the temperature closely and much slower speed.
Ady1. OK. Look for HSS M42.
John Haine: Maybe – I researched that, but I don't knwo how to tell nor how to avoid it.
John S: Use 303 – Oh – bummer though – I got quite a bit of it.
Steve P: Hah! I wondered about that. So go big and slow.
Mick B: Another vote for 303. Bugger. Thing about a boring bar is it's really boring! All that measuring and – well – engineering stuff. I just want the damned hole. Bam.
I'm stamping now and I'm going to sulk.
Ian S: It's a small Chinese lathe.
OK, so I'll but ONE new 20mm blacksmiths drill and try drilling in one go – slow – after a small pilot.
If that fails I'll try 303.
Thanks very much for all your help.
