I normally drill mine 5 or 6mm, rather than 8mm.
My Manchester Rapidor Minor takes 9" blades, so I shorten what's available; the short remains make useful scrapers etc.
I use one of the drills out of a set bought at a model engineering show many years ago.
They look a bit like masonry drills, and are often demonstrated at autojumbles, and car shows, by a chap who drills holes in files and bearings; he also sells aluminium "solder".
I clamp the blade, closely and tightly, to a piece of sacrificial mild steel using a toolmakers clamp next to where I want the hole. One jaw of the clamp is then held in the drill/machine vice.
Quite a lot of pressure and fairly high speed, to generate a good deal of heat, but not enough to melt the brazing on the tip.
If the sacrificial steel bar is fairly thick, it does help everything getting just too hot, you're looking for localised heating at the cutting edge of the drill; I might try a copper bar one day.
On a smaller scale, for a 9" hand hacksaw frame I bought recently, I use a PCB solid carbide drill, again with a sacrificial backing piece, running in a high speed Meddings bench drill; they are available in sets, cheaply off ebay.
Bill
