drill sharpening
drill sharpening
Home Forums Workshop Techniques drill sharpening
  • #15471
    david lockwood
      @davidlockwood10028
      david lockwood
        @davidlockwood10028
        Hi there all i am in the process of making a drill grinding jig for my cutter grinder to grind drills by the 4 or 6 facet method as i was shown at the Harrogate show last year. the problem is i have no idea what the clearance angles should be. any advice?   thanks in advance for any help
        David
        #51634
        Versaboss
          @versaboss
          Hi David,
          on my Meteor drill grinding machine (for small drills,  from 3 mm down) I use a primary angle between 4 and 7 deg. (4 for hard materials, 7 for soft stuff). The secondary angle is given by an end stop around 24 deg. Istr that I have seen similar values somewhere in ME (Chaddock article about drill grinding on the Quorn perhaps?), and think that a third angle would be over 40 deg. Take this with a grain of salt, maybe my memory ain’t what it once was
          Hansrudolf
          #51641
          Terryd
            @terryd72465
            I don’t know if this is any use but it may be worth a look:
            as may this place:
            terry
            Edited By David Clark 1 on 12/05/2010 12:14:11
            #51652
            Circlip
              @circlip
              Luv it Terry, wish DC1 would stop modding your long
               links and get the web design whiz  kids to sort it
               properly.
                Regards  Ian
                7th Jan & 4th Feb 94
               16th Aug & 20th Sept 96
               2 sets of articles in ME by D.A.G. Brown on 4 & 6 Facet grinding
                You got a PM David Lockwood
              Edited By Circlip on 12/05/2010 12:15:55
              Edited By Circlip on 12/05/2010 12:20:55
              #51653
              David Clark 13
                @davidclark13
                Hi There
                Links carefully modified.
                regards David
                #51667
                david lockwood
                  @davidlockwood10028
                  Thanks for the posts everyone. Terryd the links were very interesting
                  #110319
                  Old Raft
                    @oldraft
                    Try http://www.gadgetbuilder.com/DrillSharp.html for "some" information.
                    If you find actual plans for any of the jigs mentioned please let me know.
