Can anyone help? I have a Black and Decker cordless drill, model EPC188.
This performs and does everything I want it to. Problem is the useless keyless chuck. It won't even hold a 3mm masonry drill when the hammer is engaged.
I have removed the screw from inside the chuck.
There are two flats behind the chuck that require a spanner on each. however the screws that hold the front plate to the body partially foul the body flats and the chuck flat is only 2mm deep. the total gap between chuck and body is 5mm.
How do I get the chuck off?
