Posted by Wolfie on 20/09/2012 12:34:04:
I have to say that I would have thought it was blindingly obvious to put the left hand side projection on the left, and the right hand side on the right, the top at the top and so on. Who would do it any other way???
3rd angle is only used America and Australia, the rest of the world uses 1st angle ortho – so not really that obvious, and not "as previously used in the UK" either – it really depends on your way of thinking.
The easiest way to understand the difference is by imagining that your "object" never leaves the page, – now this is a fairly lose analagy from my brain – for a proper insight, as I think previously linked see here – but you might get bored quick, even though the page contains less words than this post……. http://www3.ul.ie/~rynnet/orthographic_projection_fyp/webpages/third_angle.html
1st angle, the object sits ON TOP of the page, and so rolling to the left, displays the right side of the object (assuming its a cube or simple shape)
3rd angle, imagine the object is under the page, rolling it to the right, displays the right side.
now if you think about 3rd angle from a 1st angle persons perspective, you can see where it gets its name from, as from a 1st angle persons way of working, you'd have to rotate the part 3 times to get an adjacent view.
If you look back to the cups, it should make sense now, page under…… page over etc. =) – the iso view is for folk who can't read 1st & 3rd angle and don't know the difference between a hidden line and a normal line as 1st or 3rd angle – doesnt matter, same information, different arrangement on the page!
Sry I'm editing like a bugger ignore what I just said, imagine a drawing of a dice with a printed symbol on each face. Lines and fetures wont position each face so unless you knew if you where look at a 1st or 3rd angle, you couldn't possibly arrange the symbols correctly as the draughtsman intended (maybe its loaded….. or why would it matter lol, loose example)
Also, yes 3rd angle is also acceptable in the UK, but as my boss and mentor would say if I turned out a 3rd angle drawing, "we don't work in imperial any more, its EN, not BS from here on"
Edited By Russ B on 06/03/2014 00:35:07
Edited By Russ B on 06/03/2014 00:43:36
