Hi Guys
Thank you all for taking the time to reply;
Speedy Builder 5: Yes that’s what I was worried about the O ring squashing outwards as it’s not really contained in that application.
I’ve been having a look at some of the sites you guys have suggested and from what some of you have said a crushable copper washer may be the direction to go.
I’ve included a bit of a sketch to illustrate what I’m trying to get right, you will see the undercut is 3mm wide so obviously any washer thinner is going to drop down into the well creating a gap as shown in view Section A – A.
There must be some way around this, another thing I often find when looking for copper washers is the land always seems to be very narrow, I always have a job finding something the size of the washer I‘ve included a photo of.
I agree with all of you the last thing I want is an oil trail and as already pointed out a very expensive learning curve.
Jeff Dayman: I fully understand what you are saying about videos one does have to be careful.
A parts manual would be very useful, heaven knows where I would find one for an Isuzu Trooper 3.0TD because that’s the car we are talking about.
Emgee: That’s what I’ve been doing until now, putting a bit of sealer over the whole sealing washer but I thought it worth coming on the forum just to find out what others do in the same situation.
JasonB: New plugs, they are on a back order though the main agent and on these Troopers there are 2 plugs on the gearbox fill and drain obviously, 2 on the transfer case, 1 of that size on the front diff, 2 on the rear diff and 1 on the shift on the fly.
So, I’m looking at 8 plugs, the price from the main agent when they have them in stock is £5.31 + vat each plus postage.
I'm not sure of the price for the sump plug and it's a different size anyway.
The service on these Troopers pops up every 6000 miles, so yes if I can find an alternative to the main agent I will.
No topping up of oils on these cars it’s drain and throw away and fill with new every time.
Thanks again fellas for taking the time to reply it’s much appreciated
Edited By Clive B 1 on 27/07/2018 15:00:40
