Drain plug
Drain plug
Home Forums General Questions Drain plug
  • #662721
    Milly S
      @millys
      Hi all I want to change the oil in my Chipmaster
      headstock can’t seem to find drain plug
      found the drain plug for gear box
      can anyone help please
      this is the metric lathe
      cheers
      steve
      Milly S
        @millys
        Colchester Chipmaster
        #662733
        Stuart Bridger
          @stuartbridger82290
          looking at the chuck from the tailstock end, bottom right of headstock.
          #662808
          not done it yet
            @notdoneityet
            I rarely change the engine oil in my car by draining. I use a vacuum device to ‘suck’ it out. Most dealerships likely do it this way, if possible.
            If it is a hydraulic system with pump, i would likely run the pump to empty the oil reservoir.
            ‘Outside the box’ often comes up with a viable alternative.
            #662910
            Milly S
              @millys
              Thanks Stuart & not done it yet
              i had used hose to siphon oil out of filler cap
              which worked fine but a little slow just wanted to know
              where drain plug is for future reference might have to
              strip headstock as knocking noise suddenly appeared
              cheers
              steve
              #662913
              Chris Pearson 1
                @chrispearson1
                I trust that Milly has an answer, but by way of thread drift, my modern car has no dipstick so the only way out is via the drain plug. Somewhere in there must be a level gauge.
                #662916
                not done it yet
                  @notdoneityet
                  Posted by Chris Pearson 1 on 04/10/2023 23:03:21:
                  Further aside, cars with turbos (or those blocks) often have access to the turbo (or would be) drain, so might even have a dipstick (if old enough) and be drained from the other side of the engine to the dipstick. I think our peugeot 2 !/4 diesel was thus equipped?
