I find mysefl a bit stuck with a domestic scenario and as the range of expertise in this forum (or at least opinion) seems limitless I thought I'd seek here for help.
Number two son (15) has a chinese water dragon.
In case of doubt, the lizard is the beast on top.
They get quite big, 2 feet (60cm) and more and so we required a largish housing. 4 foot high and wide and 2 foot deep (the younger element can do their own conversions).
I won't bore the thread with the story of the mis-delivery, mis-assembly and final bodge of the housing, nor the replacement of the ill fitting glass with an acrylic front. It would just make me cross.
Now the point here is in the name. Chinese WATER dragon. They like it damp. They want a swimming pool which must be changed every day (among other things this is their toilet).
In hindsight, a contiboard enclosure seems like a very poor design decision (not mine, recommended by the shop) for a basically wet environment.
A while back I put some pond liner in the bottom, though I confess that the gluing up the sides wasn't too brilliant (why do adhesives and paint only ever cover 70% of what it says they can on the tin?).
Recently we discovered mushrooms growing in the lizard home. And little white spores all over the place. Gandalf (Lizard, not son) had taken to perching on the topmost branch glaring enigmatically (to be honest, his range of emotional expressions is pretty limited).
Well, Lizard has been despatched to Lizard holiday home whilst we work out what to do. Bear with me. I'm nearly at my question!
So I've stripped out everything from the vivarium (wot we lizard people call a lizard house) and pulled up the pond liner.
Much as I expected, water has leaked underneath it and the contiboard base has not succeeded in holding back the water. There is at least one soft spot of about 6 inches diameter, though no marked breaks in the surface.
Turning it over reveals that the underneath has got wet and mouldy. So to the floorboards, though 100 years of gloss paint has prevented further damage.
The base has swollen a bit, but is holding together OK.
What I'm thinking to do is to let it dry for a few days, replace the liner, but with plenty of glue / sealant to keep it watertight and then raise the vivarium on blocks to keep the underside off the floor and aired.
Number two son want's me to build a new bigger one out of glass. My response was short and succinct.
I am a bit worried about the contiboard's longer term stability now it's gotten wet. It has definitely swollen round the edges by 20% or 30% and most likely more in the middle. For all that, the structure seems stable and of course, it's not going to have much load.
It's one of those 'bodge it or break my back' decisions, but I really don't want it to fall apart in the middle of the night in 3 months!
Thanks in anticipation of some interesting advice!
Iain
