Doug Hewson BR Standard Class 4
Home Forums Drawing Errors and Corrections Doug Hewson BR Standard Class 4
  • #764485
    chris hammerton
      @chrishammerton30410
      I been looking at the frame drawing in of the BR Mogul  in ME4750.
      As far as I can see it is, in the main, fully defined but I think there are a couple of bits that not fully defined.
      One is very minor (I think). It concerns the line in front of the leading axle box cut out. However, by reference to the other cutouts I think a reasonable estimate can be made
      The other concerns the dip in the upper edge of the frame between the middle and trailing axle. Neither its position or its width is given. The position can probably be taken to be centralised between the axles. However without the width or the start point of one of the curves that section is not fully defined. I can make a estimate by measuring from the drawing and given that the feature looks to be cosmetic, is this acceptable?
      Chris Hammerton
      duncan webster 1
        @duncanwebster1
        Welcome to the world of ME drawings. At least a missing dimension is better than a wrong dimension
        #764600
        Baz
          @baz89810
          Doug Hewsons drawings are some of the best available, if you contact him I am sure he can provide the dimensions you want.
          #765603
          chris hammerton
            Thanks for your replies.
            I agree his drawing do look very good. I am sure that if they were critical  he would have included the dimensions.
            Chris
