Double Taper (DT) Collets
Home Forums Workshop Tools and Tooling Double Taper (DT) Collets
  • #632276
    Grindstone Cowboy
      @grindstonecowboy
      In the pile of bits and pieces that came with my Boxford lathe, there is a nice MT3 collet holder with drawbar – I have deduced that it takes Double Taper or DT collets in the Z size range.
      Unfortunately I only have one collet, a 7/16" and it looks like they are not all that common and not cheap when you can find them – around £25 each or more.
      Do you think it's worthwhile trying to get any more, or should I just go for ER32 instead? Which would also make it possible to pass material all the way through with the right sort of holder.
      Bonus question – if I keep it just for doing some light milling with a vertical slide, what diameter milling cutter would have a 7/16" shank?
      Thanks,
      Rob
      Grindstone Cowboy
        @grindstonecowboy
        Worth pursuing, or just go the ER route?
        #632292
        Baz
          @baz89810
          Go for ER32. Never seen a milling cutter of any size with 7/16 dia shank.
          #632294
          noel shelley
            @noelshelley55608
            3/8" and 1/2"! Milling cutters were not normally made with a 7/16" shank. Noel
            #632312
            old mart
              @oldmart
              The er sizes are very easy to get hold of, being so widely used. The er 32 go up to 21mm and the er40 go to 26mm. If you also have a mill, they can be used on both machines which is convenient.
              #632320
              Grindstone Cowboy
                @grindstonecowboy
                Thanks chaps! As I suspected, it's essentially useless – I was kind of hoping someone might suggest a source of collets at £1 apiece, but… wink
                I'll revert to my original plan of ER32.
                Thanks again,
                Rob
                #632334
                Gavlar
                  @gavlar
                  I have no experience of DT collets. So at the risk of embarressing myself, could your collet set possibly be 3c? The standard Boxford collet holder and drawbar are for 3c collets
                  #632336
                  Grindstone Cowboy
                    @grindstonecowboy
                    Hi Gavlar
                    No, afraid not – I think it's something the previous owner (a lifelong engineer) acquired somewhere along the line. It's definitely one of these.
                    Rob
                    Links to http://www.tools-n-gizmos.com/specs/DT_Collet.html
                    #632341
                    Grindstone Cowboy
                      @grindstonecowboy
                      #632343
                      Les Riley
                        @lesriley75593
                        Some years ago I too got a DT chuck and one collet. Not much use so I put it in the cupboard. More recently, I bought a machine that came with a big box of DT collets so I am glad I didn't throw it away!
                        #632536
                        John Reese
                          @johnreese12848
                          The DT collets have a clamping range of only a few thou from their nominal size. ER collets in the larger sizes will hold work up to 1mm below nominal. That is a big advantage for holding drills or taps.
